BMW GS1200 motor
Re: BMW GS1200 motor
Eish R50k!!! If you don't want it, I will buy it!
-justin
-justin
- Stephan van Tonder
If you not going to take it send me the contact detail please.
The 1150 is an excellent engine . The Bosch motronic is also superb it is single ignition also single fuel At present my first engine is a 1100S with The Bosch Motronic and the second system is our Eboxi. It is super reliable and I have done 260hrs had to use the Eboxi once because the Motronic was water saturated after very heavy rains that saturated my trike when I towed it on holiday. It was wonderful when the Motronic stopped and I switched to the Eboxi and the rest of the flight was uneventful. The trike dried out and the Motronic is faultless. The Eboxi can be fitted afterwards if the owner so desires. On the twin spark engines it is a non event on the single plug engines it means adding the second spark plug If somebody is interested I can give all the procedures and details. There is plenty of meat in the cyl head to machine the second plug hole.
Cheers Oupa-G
Cheers Oupa-G
- External view of secong plug
- Plug1.jpg (68.37 KiB) Viewed 3022 times
- Note the second plug is a 10mm plug size
- Plug2.jpg (77.57 KiB) Viewed 3024 times
Roel Jansen
ZU-IAR powered by BMW 1200
I can't help you with the price but I can tell you they are very good engines properly installed
Cheers Oupa-G
Cheers Oupa-G
Oupa-G,
I promise you that I am not the type (nor have the time) to start with re-designing the wheel. If I intend to install it, are you the man to do it, I think so.
Back to one of my first questions. Can we (you) install it on a Windlass under carriage ? Secondly, what wing should I be thinking about if I want to utilze the full potential of the motor ?
I have this dream of a Jenya topless, a Alex undercarriage and a motor of my choice.
Is this possible ?
Is this possible ?
Roel Jansen
I made the deal. Not quiet R 50 K, but close. Motor to be sent to BMW (SA) tommorrow for its 1 year or 2500km service, compliments of the sellers.
Gracia
Gracia
Roel Jansen
Jy nou gatvol vir two-strokes??
Nee, glad nie Boet. ZU-AZP behoort weer binne die volgende maand te vlieg. Maar die engine-out op AZP het my aan die soek gesit. Vandaar dat ek die BMW enjin opgespoor het.
My gat juk bietjie. Terwyl ek AZP (2 stroke) vlieg, wil ek begin bou aan 'n 2e trike. Ek het die BMW gekoop vir minder as 'n kwart van 'n 912 enjin se prys. Die besparing gee my finansieel baie opsies. Oorweeg miskien 'n topless Jenya vlerk, maar ek soek nog 'n geskikte platform (karretjie) wat as kombinasie kan dien. 'n GT450 karretjie, of soortgelyk.
Miskien moet ek "post" onder "aircraft wanted" ?
Anyway, sien uit na die projek. Wat vlie jy ?
Roel Jansen
Cobra 'karretjie' with a jenya wing and a BMW motor should make a nice combo?.
http://www.aerotrike.co.za/main.html
I couldnt agree with you more. Perfect combination.Stephan van Tonder wrote:Cobra 'karretjie' with a jenya wing and a BMW motor should make a nice combo?.
- MYR
- Solo cross country
What would be the price of a new 1200 BMW engine in SA ?
I'm a French speaking person. Sorry for the mistakes I can make.
If you don't understand what I say, do not hesitate to tell me.
Je fréquente aussi le forum : Le forum des ULM-ELA-LSA
- John Boucher
I think it is in the region of R 48000 excluding all the attachments such as fuel injection etc. One could then regard it as a SHORT BLOCK!
Could be more now due to increases, exchange rate etc.
