Prop Balance
Aerosan
Postby Aerosan » Sat Jun 02, 2007 7:30 am
Bennie Vorster wrote:
Thank's you all. I also have it as 13 NM, but it seems to be a bit loose.
Well I wouldnt mind a 13NM mistress, but I suppose a 12 NM one will be better :wink: :arrow: loose for sure... :twisted:
Bennie Vorster
Postby Bennie Vorster » Sun Jun 03, 2007 8:15 pm
Ok, next prop question.
Is it possible to send a three blade wrap prop for maintenance or do you have to simply replace it? :roll:
Bennie Vorster
083 277 5110
Postby Morph » Mon Jun 04, 2007 11:48 am
Bennie Vorster wrote:Ok, next prop question.
It depends on the make. I know Warp Drive props can and do replace blades for you. You give them the serial number and they send you a new blade. Woodcomp don't :shock: :twisted:
If you do repair the blades using glue etc you must rebalance it, slightly more complicated than the two blade but using the same technique and applying a little bit of spray to the highest blade until it hangs flat. If you can send it in to Pieter.
Bennie Vorster
Postby Bennie Vorster » Mon Jun 04, 2007 6:52 pm
Thanks Guys I think Ill send it to Piet as soon as the BB is in the air. :wink:
Bennie Vorster
083 277 5110
jabirusk
Found a flight school
Prop Balancing
Postby jabirusk » Tue Jun 19, 2007 8:59 pm
If friction holds the prop in place and not the prop bolts, howcome my Jabiru has bushes that go halfway into the bolt holes? Here, the prop isn't gonna move one mm.
ZK-CEN,Jabiru
saraf
Vibration Equipment
Postby saraf » Wed Jun 27, 2007 10:08 am
HI Guy's
My Father bought Vibration Analyses equipment when we were in Canada.
I played around with it on 2 RAF's , they have warp drive props (4 blades)
Run nr. 1 Vibration was 2.100 inches of vibration per second.
After I was finished I got it down to 0.152 inches of vibration per second. Industry standard is 0.300 i/v/p/s. I also played around on the other gyro and got that one from 1.9000i/v/p/s to 0.250 i/v/p/s. Makes a huge difference...
I have not played around or done 2 bladed props but the proses is the same on any prop. When I have the Equipment here in Cape Town again I will let you know. :)
Eben Jnr
