And believe me Duckie here has a wealth of knowledge. ut just for the recod can anyone tell us what the real difference is?
taaipitperske wrote:"n Hele paar 'engine-outs' het die telefoonlyne laat gons en om hulself te vrywaar teen siviele eise, is die "geen mikroligte gebruik" op die verpakking aangebring.
A translation for the non Afrikaans speakers. (Sorry if it is a bit inaccurate)taaipitperske wrote:So 'n paar jaar gelede het 'n klomp 'NGK' plugs vanaf 'n Oosterse land onwettig die land binne gekom. Die verpakking was baie goed nageboots en die verskil kon slegs op die vonkprop self (die inskripsie het verskil) gesien word.
Ek self het in die tyd oorgeslaan ne Bosch W4CC vonkproppe en nog nooit (+2000 ure) weer NGK gebruik nie. Verbranding is beter en die vonkproppe hou beslis langer
Sure, it makes sense and that's good inputalan wrote:....The plugs in the red box have the screw on cap which I have seen a spark plug lead come off as the plug had unscrewed.
Make sense?....
HuhLeprachaun wrote:The BR8ES plug from NGK is the Correct one......BR8ES - DO NOT USE A RESISTOR plug as you can damage the stator coils
