Magnetic field strength
pierre
Postby pierre » Sat Nov 26, 2016 2:55 pm
OK every body is up to date with the magnetic declination. We here in PE is ( -28° 4' ( Fine ))
Gauteng is ( Magnetic declination: -18° 41' )
Cape Town (dorpie (**) ) is ( Magnetic declination: -25° 14' ($$)
If you look at this site ( Please look here )
http://www.magnetic-declination.com
the Magnetic field strength is : 26621.0 nT
Up in Africa is Cairo : 43707.1 nT
so it goes up ( north ) : 56~ nT ( N)
Question ( How on EARTH is it possible that the Magnetic field strength can very
on earth???
Biggles
Re: Magnetic field strength
Postby Biggles » Tue Nov 29, 2016 10:53 am
The short answer is that the earths magnetic field is generated by a big solid blob spinning in a big molten blob incased in an oblong blob. So the classic image of the magnetic field lines looking like a highschool science class magnet is not exactly accurate. The shapes of the blobs (and probably their offset from the axis of rotation) determine field strenght. As you also know that they change with time and mag declination in displayed with a date with an average annual change. I recall there are older airfields with runway numbers that no longer match there current magnetic heading.
Trike pilot
ZU-DLP
Winelands FAWN
Biggles
Postby Biggles » Tue Nov 29, 2016 11:47 am
Oh, yes and we are overdue for a magnetic field reversal. Magnetic fields are weakening so scientist believe we are at the start of a reversal.
Trike pilot
ZU-DLP
Winelands FAWN
kloot piloot
Postby kloot piloot » Wed Nov 30, 2016 11:54 am
The further you move away from a magnet, the weaker the magnetic field would be. Hence the decreasing strength numbers when moving south.
Roel Jansen
ZU-IAR powered by BMW 1200
Biggles
Postby Biggles » Thu Dec 01, 2016 11:52 am
Magnetic field strenght
Trike pilot
ZU-DLP
Winelands FAWN
Horned Adder
Postby Horned Adder » Thu Dec 01, 2016 3:51 pm
Nice Biggles (^^) (^^)
To fly is Heavenly but to Hover is Divine!
