Who in SA fly this kind of plane??
Divan rossouw
Postby Divan rossouw » Mon Sep 28, 2015 1:15 pm
Hi there. I want to know if any one in SA own a Fisher Horizon 1that is flying. And if there is any instructors who can give a rating on these planes. I am far from finish building my own but I just want to know if I can do a rating on this type of plane before my own is finished so I can do the proving hours on it. My number:0718950749. Have a nice day
justin.schoeman
Re: Who in SA fly this kind of plane??
Postby justin.schoeman » Mon Sep 28, 2015 2:10 pm
None registered in SA. You will probably need to get your test pilot to do your conversion after the initial test flight.
Divan rossouw
Postby Divan rossouw » Mon Sep 28, 2015 3:03 pm
Thanks alot Justin. So if I have my test pilots licens then I can fly it with out going for a rating or how does it work? I dont have a licens yet so I am not familiar with every thing that I need to do to be able to fly the plane when it is finished. Regards
Divan
justin.schoeman
Postby justin.schoeman » Mon Sep 28, 2015 3:29 pm
Divan rossouw wrote:Thanks alot Justin. So if I have my test pilots licens then I can fly it with out going for a rating or how does it work? I dont have a licens yet so I am not familiar with every thing that I need to do to be able to fly the plane when it is finished. Regards
Divan
I am not sure myself - I think you either need a Class 1 Test Pilot rating, or a Class 2 with open type rating to test fly a type you are not rated on. A rated test pilot only need to perform the first and last test flights. A type rated owner can complete the rest of the proving flights.
Divan rossouw
Postby Divan rossouw » Mon Sep 28, 2015 4:44 pm
Oh okay thanks alot. I will make sure about everything. Do you maby know what is the minimum hours needed to get the necessary test pilots licens
Goose
Postby Goose » Mon Sep 28, 2015 8:39 pm
Divan rossouw wrote: Do you maby know what is the minimum hours needed to get the necessary test pilots licens
For Class-2
500hr TT with 350hr PIC
Divan rossouw
Postby Divan rossouw » Thu Oct 01, 2015 4:06 pm
Oh okay dankie baie oom. Dan gaan iemand anders 10 teen 1 die proving hour vir my moet vlieg...groete vhpy
