N C prop balicing
zucac
N C prop balicing
Postby zucac » Fri Jul 18, 2014 4:02 pm
I have two NC props that weigh 720 g each and two that weigh 686 g
I need to make three off the same weight .
I can swop some one with a spare one with a similar weight or
make one off the props the same as the other .
thanks
Brett
witwillem
Re: N C prop balicing
Postby witwillem » Wed Jul 23, 2014 8:17 am
Yes man it looks like you got aproblem, if you comes here to Rustderwinter dam and you brings the , the we takes them two by two , yous and me an we takes the trek saag and we treks some of the heavy off the heavy one , but now we must be careful on the newton laws and the mathematic becuse if you takes too much you have to givetoo mucch and if you mulity with the fly in factor you end up wif 4 or 5 blades. moosa bamabjam he verneuks us boerjies like this , but we get even when he buys oorskot mielies het gets scrap metal at mielie price and we get paidmielieprys for scrap metals, so in the what goes up wif speed will come down wif speed, you can ask ronne piet els from thebrannewyn parlement who took , le mefort for you who dont know , a .303 jaggeweer and fastened it to my big six Ford se bak and make sure it was water pasin all directions and when ronne piet pulls the snelle the bulle jumps out of the the front walk and dissapearsinto eternity , just as everbody vannie brannewyn parlement want to start arguing who was righr the cortina get a hole in the top of the cab se dak , jano we have to put the areal in the hole.so to make a short story long forget all the boereraat and go the leperkoring man he got bldes new and old , hy is tans innie bed na n moere operasie on his beck , but the bergheks may get you the spares or evens better get hold of nigel couts who mkes them , hy wil darem ok seker n aal moesie makk of hoe willimpie oppi vlakte (**)
