Important NOTAMs re Airspace Restrictions This Week!!
Postby Bundy » Sun Dec 08, 2013 7:15 am
Fellow Aviators,
Please take note of the following Notams issued IRO Temp Airspace restrictions for Mandela's Funeral! (taken from AvCom)
http://www.avcom.co.za/phpBB3/viewtopic ... 1&t=126647
Please find the NOTAMS as requested below:
Please read carefully! This will affect many pilots operating around JHB, EL and the Transkei!
Please also note the requirement for transponders :(
(A4177/13 NOTAMN
Q)FAJA/QACXX/IV/NBO/AE/000/076/2550S02813E005
A)FAWK B)1312061430 C)1403062200 EST
E)CTR MANNED H24 ON 124.1 MHZ
F)GND G)7600FT AMSL)
(A4178/13 NOTAMN
Q)FAJA/QRTLP/IV/BO/AW/000/076/2544S02812E001
A)FAWK B)1312082201 C)1312142200
E)UNION BUILDING, 1NM RADIUS CENTERED AT: 254426.15S 0281242.61E EXTD FM GND TO 7600FT ALT PROHIBITED FOR ALL FLT DRG THE DECLARED TIME PERIOD.
(A4179/13 NOTAMN
Q)FAJA/QRTLP/IV/NBO/AW/000/460/2609S02814E050
A)FAOR B)1312082201 C)1312142200
E)MILITARY AIR DEFENSE IDENTIFICATION ZONE DECLARED, ENCOMPASSED BY A 50NM RADIUS CIRCLE AROUND VOR JSV (S260925 E0281351) EXTENDING FROM GND TO FL460, INCLUSIVE OF ALL EXISTING DECLARED AIRSPACE. THE ADIZ INCLUDES ALL EXISTING PROMULGATED AIRSPACE.
NORMAL PUBLISHED PROC TO ENTER AIRSPACE LISTED ABOVE ARE TO BE COMPLIED WITH. IN ADDITION ALL FLIGHTS, INCLUDING STATE AND SCHEDULED FLIGHTS, FLYING WITHIN THIS AIRSPACE ARE TO APPLY TO THE SAAF FOR AUTHORISATION AT LEAST 24HR PRIOR TO COMMENCING THE FLIGHT. ALL FLIGHTS OPERATING WITHIN THE LATERAL BOUNDARIES OF THIS AIRSPACE ARE TO SUBMIT ATS FLIGHT PLANS. THE FLIGHT AUTHORISATION CODE (FAC) FOR EACH FLIGHT MUST BE INDICATED ON THE FLIGHT PLAN IN FIELD 18, EG RMK/FAC...........
ALL FLIGHTS OPERATING WITHIN THE LATERAL BOUNDARIES OF THIS AIRSPACE MUST BE TRANSPONDER EQUIPPED.
APPLICATIONS FOR FLIGHT AUTHORISATION CAN BE SUBMITTED TO THE SAAF VIA E-MAIL OR TELEPHONICALLY TO THE FOLLOWING: FLIGHTAUTHO(AT) TELKOMSA.NET OR 0123122626 (PHONE).
AUTHORISATION OFFICE WILL BE MANNED 24HR FROM 07 DEC 13 06:00Z
F)GND G)FL460)
(A4180/13 NOTAMN
Q)FAJA/QRTLP/IV/BO/AW/000/076/2550S02813E005
E)AIRCREW TO NOTE THAT FAWK SAAF ATC MAY REFUSE PERMISSION TO TRANSIT THROUGH THE FAWK CTR, WITHOUT PN.
(A4181/13 NOTAMN
Q)FAJA/QRTLP/IV/BO/AW/000/076/2608S02815E005
A)FAOR B)1312092201 C)1312102200
E)TEMPO PROHIBITED AIRSPACE DECLARED, ENCOMPASSED BY A 3.5 NM RADIUS CIRCLE AROUND (261405.23 0275857.48) EXTD FM GND TO 7600FT ALT. NO FLT ALLOWED IN THIS AIRSPACE, UNLESS UNDER SPECIFIC SOUTH AFRICAN AIR FORCE (SAAF) MILITARY CONTROL.
(A4186/13 NOTAMN
Q)FACA/QADXX/IV/BO/AE/000/460/3133S02840E005
A)FAUT B)1312102201 C)1312192200
E)MILITARY ADIZ DECLARED, ENCOMPASSED BY A 50NM RADIUS CENTERED AT 313252.47S 0284027.70E EXTD FM GND TO FL460. THE ADIZ INCLUDES ALL EXISTING PROMULGATED AIRSPACE. NML PUBLISHED PROC TO ENTER AIRSPACE LISTED ABOVE ARE TO BE COMPLIED WITH. IN ADDN ALL FLT, INCLUDING STATE AND SCHEDULED FLT, FLYING WITHIN THIS AIRSPACE ARE TO APPLY TO THE SOUTH AFRICAN AIR FORCE (SAAF) FOR AUTHORISATION AT LEAST H24 PRIOR TO COMMENCING THE FLT. ALL FLT OPERATING WITHIN THE LATEARAL BOUNDARIES OF THIS AIRSPACE ARE TO SUBMIT ATS FPL IN FLD 18, EG RMK/FAC.......
ALL FLT OPERATING WITHIN THE LATERAL BOUNDARIES OF THIS AIRSPACE MUST BE TRANSPONDER EQUIPPED. APPLICATIONS FOR FLT AUTHORISATION CAN BE SUBMITTED TO THE SOUTH AFRICAN AIR FORCE (SAAF) VIA E-MAIL OR TELEPHONICALLY TO THE FLW:
FLIGHTAUTHO(AT)TELKOMSA.NET OR +27123122626.
AUTHORISATION OFFICE WILL BE MANNED H24 PER DAY FM 07 DEC 2013 0600Z.
F)GND G)FL460)
(A4189/13 NOTAMN
Q)FAJA/QRTLP/IV/BO/AE/000/460/2608S02815E005
E)REF NOTAM A4179/13. MILITARY AIR DEFENSE ZONE DECLARED, ENCOMPASSED BY A 30NM RADIUS CIRCLE AROUND VOR JSV (260925.62S 0281351.69E) EXTD FM GND TO FL460, INCLUSIVE OF ALL EXISTING DECLARED AIRSPACE. NO TRAINING FLT ALLOWED IN THIS AIRSPACE.
F)GND G)FL460)
(A4193/13 NOTAMN
Q)FACA/QARCA/IV/BO/E/090/460/3202S02323E511
A)FACA B)1312100600 C)1312161400 EST
E)DUE TO INCREASE OF TFC IN THE FAEL, FAUT AND FAPE AREA, THE FLW COMPULSORY AMENDED ROUTE STRUCTURE WILL APPLY. SOME ROUTES WILL RESULT IN INCREASED TRACK MILES TO DECONFLICT TRAFFIC SO FUEL PLANNING MUST BE DONE ACCORDINGLY. ATC WILL ENDEAVOUR TO SHORTEN THESE ROUTES, WHENEVER TFC PERMITS.
OUBD TFC: FAEL TO THE N TO ROUTE VIA BOV AND GESEP TO JOIN THE UZ5.
FAEL TO THE E, W OR SW WILL BE POSITIONED SEAWARDS OF THE COASTLINE BY ATC FOR ONWARD RADAR ROUTING. FAPE TO THE E (FALE) WILL BE POSITIONED SEAWARDS OF THE COASTLINE BY ATC FOR ONWARD RADAR ROUTING.
FAUT TO THE N TO ROUTE DCT STV. FAUT TO THE E TO ROUTE DIRECT DEST.
FAUT TO THE W TO ROUTE VIA ERBIK. FAUT TO FAEL AND FAPE WILL BE REQUIRED TO ROUTE VIA THE POINT ELV072060. FABE TO THE N AND W TO ROUTE GESEP. FABE TO THE E WILL BE POSITIONED SEAWARDS OF THE COASTLINE BY ATC FOR ONWARD RADAR ROUTING.
INBD TFC: TO FAEL FROM THE N AND NW TO ROUTE IBTOV AND UVBIG. TO FAEL FROM THE E TO ROUTE VIA PJV OR ESTAG. TO FAEL FROM THE W TO ROUTE VIA EGPUL. TO FAPE FROM THE E (FALE) TO ROUTE VIA PJV, ELV AND PEV FOR RADAR VECTORS. TO FAUT FROM THE N ROUTE VIA PJV FOR RADAR VECTORS TO GNSS APCH FOR RWY IN USE. TO FAUT FROM THE W TO ROUTE VIA EPLUK FOR RADAR VECTORS TO GNSS APCH FOR RADAR VECTORS FOR THE RWY IN USE (THIS INCLUDES TFC FM FAPE AND FAGG). TO FABE WILL ROUTE INBD AS IF FOR FAEL AND BE REROUTED TO FABE AS PER ATC INSTRUCTION.
F)FL090 G)FL460)
(A4194/13 NOTAMN
Q)FAJA/QFAXX/IV/BO/A/000/999/2608S02815E005
A)FAOR B)1312082200 C)1312172200 EST
E)DUE TO EXP INCREASE IN TFC VOLUMES, THE FLW RESTRICTIONS HAVE BEEN
IMPOSED:
1. ARRIVING NON-SCHEDULED OPERATORS ARE LTD TO A MAX APN PRKG TIME OF 30 MIN FOR OFF-LOADING AND DISEMBARKATION. THEREAFTER THE ACFT MUST BE REPOSITIONED TO AN ALTERNATE AP OR HANGAR FACILITY. (HANGAR
FACILITIES: CTC SAFAIR +27011 928 0105, DENEL +2711 927 2215, SAA
+2711 978 6694, FEDERAL AIR +2711 395 9000 OR CEMAIR +2711 395 4473).
2. DEPARTING NON-SCHEDULED OPERATORS ARE LTD TO A MAX APN PRKG TIME OF 90 MIN FOR REFUELLING, LOADING AND DISEMBARKATION.
3. SLOTS WILL ONLY BE APPROVED BASED ON SUBMISSION OF INFO STIPULATED IN THE SOUTH AFRICAN SLOT COOR REGULATION. ADDN INFO REQUIRED INCLUDES LINE ENGINEER SER PROVIDER, CATERING SER AND DEP FUEL UPLIFT
REQUIREMENTS.)
(A4195/13 NOTAMN
Q)FAXX/QSCXX/IV/NBO/E/000/460/3231S03010E187
A)FACA FAJA FAJO B)1312100700 C)1312161400 EST E)AREA BOUNDED BY
S345641 E0300644
S324634 E0270535
S304949 E0273700
S301622 E0274559
S304318 E0283553
S323335 E0321610
S325858 E0315931: TEMPO AREA CTL SECTOR ESTABLISHED.
EXCLUDING THE TEMPO FAUT CTR.
AIRSPACE CLASSIFICATION: CLASS C.
FREQ: 127.575 MHZ.
RADIO CALL SIGN: CAPE TOWN AREA CENTRAL.
F)SFC G)FL460)
(B1463/13 NOTAMN
Q)FACA/QRTLP/IV/BO/AW/000/145/3148S02836E010
A)FAUT B)1312071500 C)1312191600
E)A CIRCLE RADIUS 10NM CENTERED AT (S314821 E0283621) EXTD FM GND TO
FL145 IS RESTRICTED FOR ALL FLT DRG THE DECLARED TIME PERIOD, UNLESS UNDER SPECIFIC MILITARY SOUTH AFRICAN AIR FORCE (SAAF) CONTROL.
APPLICATIONS FOR FLT AUTHORISATION CAN BE SUBMITTED TO THE SAAF VIA E-MAIL OR TELEPHONICALLY TO THE FLW:
AUTHORISATION MANNED H24 PER DAY FROM 07 DEC 2013 0600Z.
F)GND G)FL145)
(C3836/13 NOTAMN
Q)FACA/QFUAU/IV/NBO/A/000/999/3302S02749E005
A)FAEL B)1312061444 C)1312170800 EST
E)NIL FUEL AVBL. ARR ACFT TO ENSURE THAT SUFFICIENT FUEL IS CARRIED.)
(C3837/13 NOTAMN
Q)FACA/QFUAU/IV/NBO/A/000/999/3254S02717E005
A)FABE B)1312061445 C)1312170800 EST
(C3838/13 NOTAMN
Q)FACA/QFUAU/IV/NBO/A/000/999/3133S02840E005
A)FAUT B)1312061446 C)1312170800 EST
(C3844/13 NOTAMN
Q)FACA/QSTAH/IV/BO/A/000/999/3302S02749E005
A)FAEL B)1312140530 C)1312162359 EST
D)H24
E)TEMPO TWR HR OF SER.)
(C3846/13 NOTAMN
Q)FACA/QSPAH/IV/BO/AE/000/999/3302S02749E005
D)H24
E)TEMPO APP HR OF SER.)
(C3847/13 NOTAMN
Q)FACA/QFAXX/IV/BO/A/000/999/3133S02840E005
A)FAUT B)1312130600 C)1312161800 EST
D)11 DEC 2013-13 DEC 2013 0600-1800
14 DEC 2013-15 DEC 2013 24HR
16 DEC 2013 0600-1800
E)TEMPO GND CTL SER ON 120.2 MHZ.)
(C3848/13 NOTAMN
Q)FACA/QFALC/IV/NBO/A/000/999/3133S02840E005
A)FAUT B)1312130400 C)1312161600
E)AD CLSD FOR ALL TFC UNLESS SPECIFICALLY AUTHORISED BY THE SOUTH AFRICAN AIR FORCE (SAAF).
AUTHORISATION OFFICE WILL BE MANNED H24 FROM 07 DEC 13 0600Z.)
(C3849/13 NOTAMN
Q)FAJA/QFALC/IV/NBO/A/000/999/2615S02809E005
A)FAGM B)1312100400 C)1312101800
E)AD CLSD TO ALL TFC.)
bobthebuilder
Re: Important NOTAMs re Airspace Restrictions This Week!!
Postby bobthebuilder » Sun Dec 08, 2013 7:58 am
Thanks Alan, I guess this was to be expected.
Byron Kirkland
Postby Bundy » Sun Dec 08, 2013 8:08 am
bobthebuilder wrote:Thanks Alan, I guess this was to be expected.
Yip... during the SWC we could at least still fly on SAAF Authorisation without a transponder though (I remember as I was a student at the time)... gonna be a lot of angry pilots and ATO's.
Turbo
Postby Turbo » Sun Dec 08, 2013 7:28 pm
sorry guys but that load of jargon and BS - means nothing to me .... can someone more experienced than me please expain what all this means to us mere mortals?
Postby John Boucher » Sun Dec 08, 2013 10:47 pm
Eish Chris... very important part of aviation... must be familiar with it but let me try and assist and decipher...
http://www.faa.gov/about/office_org/hea ... cntrns.pdf
http://www.notamdecoder.com/
Oh, it also means that mere mortals should rather find other things to do this week besides even thinking of flying for recreational purposes! If ever there exists a chance of mid-airs or missile launches ;-) it is now!
Postby Bundy » Mon Dec 09, 2013 5:23 am
Turbo wrote:sorry guys but that load of jargon and BS - means nothing to me .... can someone more experienced than me please expain what all this means to us mere mortals?
Chris, if you flying out of Springs let me translate that which is applicable to you.
In "plane" English.... :wink:
From 22h00 last night.... until 22h00 on Sat the 14th (Both times are Zulu)... you may not conduct any flight within a 50nm radius of OR Tambo airport without prior request from the SAAF for an Authorization Number and submittance of a flight plan. It further states that you may not conduct any flight within that 50NM radius without a fully functional transponder on board.
In short....you no go fly dis week chom. :(
Postby Bundy » Mon Dec 09, 2013 5:39 am
I got a few people asking me yesterday if "they" would notice if you just did a low flight around the patch? :wink:
Guys...please do not do this...you risk Jail time if caught...or worse! You have been warned....SAPS and SAAF will def be watching the skies. In 2010 there were police stationed at all the registered airfields affected (Even JAG!).
Please also spare a thought or even better a small donation to your local flying school. They are going to have a week with no income... :( Help them where you can guys! This affects them badly...
John.com
Postby John.com » Mon Dec 09, 2013 6:44 am
'Just had John Robbie read this out on 702! :wink:
"Good Morning John!
Please make a very important announcement for GA (General Aviation) pilots!
There are a large number of NOTAMs (Notice to Airman) in place over this week, in particular in and around JHB and the Eastern Cape, which largely limit GA flying.
Pilots to read NOTAMs before flying! www.atns.co.za
Many thanks, John"
John Comley
Magaliesberg, South Africa
Postby nicow » Mon Dec 09, 2013 7:18 am
Come fly by us,no vip's,and no vip bodies ^ ...
John.com
Postby John.com » Mon Dec 09, 2013 7:28 am
nicow wrote:Come fly by us,no vip's,and no vip bodies ^ ...
We may just!!!! :lol: :lol: :lol:
John Comley
John.com
Postby John.com » Mon Dec 09, 2013 7:59 am
Taking it to a level for the likes of 'me' to understand . . . graphical!! :lol:
This is the one that affects most of us in Gauteng and NWP . . . .
(A4179/13 NOTAMN
A)FAOR B)1312082201 C)1312142200 (so, from 00h01 SAST on 9 December, 2013 - 00h00 SAST on 15 December, 2013)
AUTHORISATION OFFICE WILL BE MANNED 24HR FROM 07 DEC 13 06:00Z.
F)GND G)FL460)
John Comley
bobthebuilder
Postby bobthebuilder » Mon Dec 09, 2013 10:06 am
I heard that!
Thanks mate.
Byron Kirkland
Pietb
Postby Pietb » Mon Dec 09, 2013 10:32 am
Just spoke to a Major(F) at the Clearance office and according to her it`s till the 19th at 20:00 !! :shock:
Jab ZU-FDZ
John.com
Postby John.com » Mon Dec 09, 2013 10:37 am
Pietb wrote:Just spoke to a Major(F) at the Clearance office and according to her it`s till the 19th at 20:00 !! :shock:
Thanks for this! We'll keep a lookout for an update.
Right now the posted NOTAMs rule! :wink:
John Comley
Pietb
Postby Pietb » Mon Dec 09, 2013 10:50 am
Agree John !!
Jab ZU-FDZ
