Chuck Norris the Pilot
Postby Air Hog » Sun Oct 20, 2013 10:47 am
Chuck Norris doesn’t request clearances, he states intentions.
Chuck Norris is the only person ever to land on runway 37.
Hijackers squawk 7500 when Chuck Norris is on board.
Chuck Norris once shot down three enemy aircraft with his aux fuel tank.
Chuck Norris has never landed with a crosswind. The wind would never dare get cross with Chuck Norris.
Chuck Norris doesn’t fly into headwinds…the wind is always running away from Chuck Norris.
When Chuck Norris flies, the altimeter setting is 00.00. Chuck Norris is never under pressure.
Right of Way rules do not apply when Chuck Norris is flying. If you are flying toward Chuck Norris, you are wrong.
Chuck Norris doesn’t shoot approaches…he kills them.
Chuck Norris is never off of glideslope, the glideslope is off of Chuck Norris
Two way contact for Chuck Norris is when he hits you with both fists simultaneously.
Chuck Yeager broke the sound barrier with his Bell X-1 Jet. Chuck Norris broke the sound barrier with his fist.
Chuck Norris was told to ident, the controller was greeted with a fist coming out of his radar screen.
Chuck Norris doesn’t level off; he tells the altimeter to stop moving.
Chuck Norris was once denied a clearance… once...
Chuck Norris was flying and saw a wall of clouds ahead so he decided to punch through them. He then got back in his helicopter and flew through the hole he just made.
Chuck Norris doesn’t have emergencies, only moments of brief excitement.
Chuck Norris cannot be tracked on radar, if he appears, it is too late; you are already dead.
A good flight for Chuck Norris is a bad flight for you.
A Flight Docs gives med up chits, Chuck Norris gives med down kicks.
Chuck Norris once moved a stationary front.
All survival vests will be fitted with a Chuck Norris.
Chuck Norris isn’t holding, he is circling above his victims.
Chuck Norris provides close air support via flying round house kicks.
No one knows what Chuck Norris’ tale number is, nobody has ever gotten that close.
Re: Chuck Norris the Pilot
Postby Bundy » Mon Oct 21, 2013 4:26 am
:lol:
Postby nicow » Mon Oct 21, 2013 7:16 am
=D* =D* =D*
klein
Postby klein » Wed Oct 23, 2013 7:19 am
Chuck Norris het ook n foto van Bakkies Botha bokant sy bed !! vhpy vhpy vhpy
Karnerblue
Postby Karnerblue » Sat Oct 26, 2013 10:03 am
:lol:
Born to FLY Forced to work!
