NPL aircraft
sting
NPL aircraft
Postby sting » Mon Feb 22, 2010 7:50 pm
Hi All
will this plane fall in the new mpl catogory
Min speed: 39 kt 45 mph 72 kmh
Cruise speed: 130 kt 150 mph 241 kmh
Vne: 196 kt 225 mph 362 kmh
Climb ratio: 1000 ft/min | 5 m/s
Take off distance over 50ft (15m) obstacle: 600 ft | 183 m
Max. take off weight: 318 kg | 700 lbs
Empty weight: 200 kg | 440 lbs
THI
Re: NPL aircraft
Postby THI » Mon Feb 22, 2010 8:30 pm
Don't think so. The vne for one should be 120kt or less.
This might be for microlight...
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
sting
Re: NPL aircraft
Postby sting » Mon Feb 22, 2010 8:31 pm
THI wrote:Don't think so. The vne for one should be 120kt or less.
thought it is the cruise speed ? that needs to be 120 Kts
sting
Re: NPL aircraft
Postby sting » Mon Feb 22, 2010 8:32 pm
from AVCOM
Max take off mass: 600 kg for land plane
Maximum Stall Speed at Gross Landing Configuration: 45kts
Maximum speed, level flight max cont power: 150 kts
Max no seats (incl Pilot): 2
Single engine (non turbine or jet): yes
Unpressurised: yes
Prop: Fixed or VP or CS in flight adjustable
Undercarriage: Fixed tricycle or tail wheel or retract
so it just might fall into the NPL class
Re: NPL aircraft
Postby RV4ker (RIP) » Mon Feb 22, 2010 8:41 pm
Should not be a problem. The Flamingo I am told falls into the LSA category as does the Sting RG and the Dynamic WT RG, so can't see why not this one.
This is in USA, locally they made it 150kts and include VP and RG which USA don't allow... puff
THI
Re: NPL aircraft
Postby THI » Mon Feb 22, 2010 8:45 pm
RV4ker wrote:Should not be a problem. The Flamingo I am told falls into the LSA category as does the Sting RG and the Dynamic WT RG, so can't see why not this one.
Eish...
VERY NICE AIRCRAFT :!: :!:
If I was not a gyro head, this is what I would like to fly. (!!)
Thinus Enslin
ZU-CML
sting
Re: NPL aircraft
Postby sting » Mon Feb 22, 2010 8:52 pm
so a sonerai should then fall in the same class.... as the above mentions spec is that of a sonerai
Re: NPL aircraft
Postby RV4ker (RIP) » Mon Feb 22, 2010 11:35 pm
Yes a sonerai should fall into that class. there is one in Kroonstad. Check with him. he is Sonerai on here or Avcom.
