Hi All,
I know this is non-aviation, so the moderators may delete of they see fit.
My question: Does anyone have the HD PVR system? How does it work? Is it worth it?
HD PVR
Re: HD PVR
Hi TIH
I have had one since October last year… The HD picture will blow your mind if the program is really HD, the nature programs and things like CSI are excellent.
My only complaints are:
The system is not stable and there seem to be a few bugs in the software that despite numerous software updates have not yet been resolved, it freezes, misses recordings, sometimes needs to be re-booted. Mine has been in for repairs three times, once it was completely dead, then it cam back and didn’t record and then did not find the satellite.
It also does not have the video on demand feature that the normal duel view PVR has.
All in all it is not hassle free TV, but fun to watch when it works!
Phil
Phil
How do mosquitoes get this high?
Re: HD PVR
THI wrote
However, if you want to enjoy cristal clear aviation movies then it is aviation relatedI know this is non-aviation, so the moderators may delete of they see fit.
Re: HD PVR
The software on the receivers is poor to say the least - I think the old standard PVRs and decoders have better software.
I will wait a while - and once more programming available will buy a HD PVR to receive the signal and build my own PC based HD PVR around it.
I already have a PC based PVR for standard definition which I can access from the internet to set up recordings, even stream the content of recordings to my and PCS on my home network (or if cost allowed stream to internet), and best of all - once show is recorded the software goes through the show and removes all the adverts so I dont even have to use the FFWD button on the remote.
- THI
Re: HD PVR
Interesting!skybound® wrote:I already have a PC based PVR for standard definition which I can access from the internet to set up recordings, even stream the content of recordings to my and PCS on my home network (or if cost allowed stream to internet), and best of all - once show is recorded the software goes through the show and removes all the adverts so I dont even have to use the FFWD button on the remote.
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
ZU-CML
Re: HD PVR
It is some freeware called GBPVR. (and no GB does not stand for the UK
More info at http://www.gbpvr.com/
Hardware requirements are not huge - I have a 4 or 5 year old P4 1.6 ghz machine with 1gb of RAM. Only bit you need to be picky about is the TV capture card. Must have MPEG2 built in to the hardware of the card - software level is not sufficient. Would recomend the Hauppage cards either the PVR250 or PVR 650 - expect to pay anywhere from R600-1000 for one of these.
Re: HD PVR
What happedned to the simple days where you just switched on your tv and watched a movie
Geez i dont even know which TV to buy! Plasma, LCD, led, come now why so complicated
Re: HD PVR
It is all about choice.Massimo wrote:What happedned to the simple days where you just switched on your tv and watched a movie![]()
To help you with your decision check out http://lcdvsplasma.com/ A real honest to goodness explanation regarding the pros and cons of both technologies in easy to understand terms. Problem is one needs to also begin considering the new kid on the block for HD displays - OLED. Still bloody pricey - one will set you back the same price as a second hand trike.
