crankshaft hours ???
zucac
Postby zucac » Fri Jan 11, 2008 8:21 am
my 503 was opened up at 200 hr for new piston <ran it without oil>crank was fine,will soon do a 400hr check.
RudiGreyling
Postby RudiGreyling » Fri Jan 11, 2008 11:59 am
503 on 580 hours when sold without crank problem.
Was opened up after 435 Hours and 7 years of perfect operation.
Had the crank sent in to ultrasonic and harmonic testing center to "listen" to spinning bearings. Results good to go for at least another 435 hours at similar conditions ~ 870 hours.
http://www.RudiGreyling.com
RudiGreyling
Postby RudiGreyling » Fri Jan 11, 2008 7:32 pm
Information Release By Aeroclub posted in Misasa forum under the NTCA part 24 topic but repeated here...
skidmark
Postby skidmark » Sat Jan 12, 2008 3:11 pm
My Challenger has done 486 hours and runs like a dream. Will do crank test soon with Dux's equipment for curiosisty.
Louisvw
Postby Louisvw » Sat Jan 12, 2008 10:22 pm
All the fuss about the crank and if you buy a new Rotax eng the first thing you will see is a red sticker with the words that this eng should not be use in any aircraft ,or the spark plugs got a clear picture on the box that indecate it should not be used in a microlight , is there any record of any accident where a crank had failed EICH YEA DJY SE DAAI DING
Louis van Wyk
Aero Sport
FAFK
"Safe Flying"
Crank 300hrs
Postby John Boucher » Sun Jan 13, 2008 9:56 am
I own Cheetah ZU-CXO (Ch-018)
ROTAX 582 Blue Top
Engine replaced (short block) at 750 hours. There were NO problems with engine up to that point. Used for training purposes at the time so was forced to do rebuild.
Engine has since done over 1000 hours and am now "forced" to comply as the aircraft is once again being used for training purposes!
If seriously enforced, I made the statement that the 503/582 is going to be a seriously expensive or costly engine to run where up to now it has made aviation possible for the masses.....
DarkHelmet
Postby DarkHelmet » Mon Jan 14, 2008 1:33 pm
ZU-AXC
Silver Top 582
Opened up at 290hrs by Gideon Niemann - Crank in spec, rings, seals etc replaced.
Opened up at 422hrs by Flo Momberg becasue gearbox seal needed replacing, did decoke and crank measured withing limits. Flo enquired from Aviation Engines how many hours the crank has according to the measurements - their guesstimate was approximately 290 hours.
It was noted in the logbook that I was informed about the crank that needed replacement according to manual and that I opted not to do it.
Now at 490 hours.
crank
Postby John Boucher » Mon Jan 14, 2008 2:39 pm
Can anyone give me Gideon's contact details please!
JB
DarkHelmet
Postby DarkHelmet » Mon Jan 14, 2008 2:51 pm
Gideon Niemann - Oh Ate Tree Tree Seven Won 0091
Crank...
Postby John Boucher » Mon Jan 14, 2008 3:51 pm
Thank you Dark Helmet....
Seeing that you have a Darth Vader helmet, check this out!
www.youtube.com/watch?v=7LzE_qEvWCw&feature=related
Flightstar
Postby Flightstar » Mon Jan 14, 2008 5:50 pm
503 Single ign on Flightstar : 350 hours and no problems.
503 DCDI on Windlass Trike :430 hours and no problems. Chemical decoke every 100 hours.
Silver top 582 on Aquilla: 520 hours and no problem at all.
Blue top 582 on Challenger : 39 hours and STILL GOING STRONG> :D :P :twisted: :D
Ch 701 Skyjeep (ZU-DPN)
Slabfish
Postby Slabfish » Fri Feb 15, 2008 7:27 am
503 decoked at 250hrs with new rings and now 585hrs . Still runninng puuuuurfect vhpy
Clem Slabbert from FAPX
ZS WPF Mizer-Sold
ZU EKP Jora-Sold
ZU CWE Jora-Sold
ZU IAC New Jora
rainier
Postby rainier » Sat Feb 16, 2008 8:04 am
I have owned 2 blue head 582 and one 503. I have never had anything break on any of them.
I also owned a 532. Now that was a different story. I would advise that the maintenance manual be revised for this engine - 50 hour crank replacement interval sounds about right :lol:
As I mentioned many times - I am not aware of any crank failures on either 503 or 582 engines in the Western Cape. The only place I know where these things use to go was Natal and very occasional in Joburg. AE will confirm this.
I have also noticed that - if a crank is going to fail - it will do so before reaching 300 hours in most cases (if not all that I am aware of).
I know of one 503 crank failure but I am excluding this one - it was on an engine that had not run for many years and was stored in a barn in Mpumalanga. The crank packed it in within 10 minutes of running - big end bearing crumbled to pieces. Investigation showed a lot of pitting on all bearings including the needle bearings at the small end. Engine hours on this one is unknown - no logbook found.
Rainier
Postby Duck Rogers » Sat Feb 16, 2008 1:10 pm
Rainier wrote:I know of one 503 crank failure but I am excluding this one - it was on an engine that had not run for many years and was stored in a barn in Mpumalanga. The crank packed it in within 10 minutes of running - big end bearing crumbled to pieces. Investigation showed a lot of pitting on all bearings including the needle bearings at the small end. Engine hours on this one is unknown - no logbook found.
I agree..........this one doesn't count vhpy
FlyBoy05
Postby FlyBoy05 » Sun Feb 17, 2008 9:50 am
how zit guys.
why the fuss. rotax has proven them through the years. why now. the manual states,inspection of crank seal"s,not replacement of a crank..
i am sorry for training schools because i think that most of them will just close down.
a suggestion that i think that might work,will c.a.a allow extensions on these motor"s and if so to what extend.
all of these engine"s can easily run up to a 1000 hours.
as far as i know,no crank failures in western cape either 503 and 582.
on the other and,too much opening of a engine,may result into more engine failures. who is c.a.a blaming then??
please any other suggestions. vhpy
