Castrol Super Chainsaw
Does any one know if Castrol Super Chainsaw has been discontinued? I can't get from the Midas that always had stock, and they say they not getting any? I tried few shops in Centurion and no luck
Re: Castrol Super Chainsaw
Phone Castrol in Boksburg. I use Castrol 2T. It is the one recommended by the OEM, Rotax. It costs 51 Rand / litre at Midas and is readily available.
- Nacho
- Survived second engine out
Chainsaw lube does not cover the required specifications from Rotax.
If you want to go affordable rather use the Fuchs Super 2 stroke. It has all the specifications Rotax requires.
https://www.fuchs.com/za/en/
I know oil is always a huge debate, but at least cover minimum prescribed manufacturer recommendations.
Users browsing this forum: No registered users and 102 guests
