SOLD SOLD SOLD SOLD SOLD
Specs:
Rotax 912 uls 100 HP engine. Total time 615hrs. All bulletins, mods etc., up to date, eg., all rubber hoses, fuel pump etc., just done less than 40 hours ago. Log book accurately reflects all servicing etc.,
Propellor Warp Drive 3 blade composite ground adjustable. Less than 170 hours. Previous propeller, Italian SITI, hub corrosion failure.
Prop spinner glass fibre, factory supplied.
Cockpit instrumentation as per photograph, but if you want details PM me. All the standard Rotax engine management instruments, plus VSI, ASI, Alti, etc., Digital EGT plus new senders, just fitted, less than 10 hours,
Icom A3 radio, with chatterbox intercom and headsets.
Transponder mode C.
General:
Permanent Rotax Carb body heating installed.
Aircraft has accident free history. Flies sweetly. NO VICES!
Fuselage, horizontal stabilizers, vertical stabilizer, elevators, flaps and ailerons Dacron re-covered by Jenya of AEROSSA, Petit airfield, approximately 130 hours Total time. Exact as per logbook. I flew the aircraft up from Ballito and left it with Jenya for 4 days before flying it back again with the new skin. The Dacron as above has been UV protected by spray coating, professionally done.
Main wing plus rudder and elevator in Trilam.
Ballistic parachute fitted.
Always hangared in fully secured hangar.
Aircraft has current ATF, and can be viewed and test flown at Groutville Airfield, KZN North Coast, just past Ballito.
Aircraft is owned outright. No third parties.
Cash sale R300 000. No VAT. New owner conversion can be arranged. Ferry flight assistance can be arranged.
Reason for sale: Unused money parked in my hangar, want to get a 182 for skydiving.
cheetah 912 ULS for sale - SOLD TO DARRELL
- lamercyfly
- GavinL-W
Re: cheetah 912 ULS for sale
Nice looking plane, when you get your 182 give me a shout, will happily jump out of it!
- Heard about flying
- Slow starter
Good Day, Has this plane been sold ?
- lamercyfly
Hi John, not yet. I am still happily flying DPC.
Regards.
David
Regards.
David
- lamercyfly
..the aircraft is back on the market..
Users browsing this forum: No registered users and 86 guests
