Hi guys
Can you please help me out with the GPS coordinates for the VFR reporting points in:
http://www.cometaviationsupplies.co.za/ ... %20JHB.pdf
(The green triangles)
I'm specifically struggling to find the following:
- "Highway Junction"
- "Silver Ball"
- "Hartebeeshoek Tracking Station"
- "Rail/Road Bridge"
Many thanks
Ant
GPS coordinates for VFR reporting points
Anthony Hugo
Crosswinds
Crosswinds
Re: GPS coordinates for VFR reporting points
Oh and if someone has the exact coords of the "Microwave Tower" north of "Gerotek Test Track" that would be great
Anthony Hugo
Crosswinds
Crosswinds
Are you referring to the SRW red and white radio mast reporting point at Harties?anthonyhugo wrote:Oh and if someone has the exact coords of the "Microwave Tower" north of "Gerotek Test Track" that would be great
Plane-less
Hi I guess so check on the map it's in orange "Microwave Tower" east of HartiesD2O wrote:Are you referring to the SRW red and white radio mast reporting point at Harties?anthonyhugo wrote:Oh and if someone has the exact coords of the "Microwave Tower" north of "Gerotek Test Track" that would be great
Anthony Hugo
Crosswinds
Crosswinds
Use Google Earth. It's quite accurate at determining coordinates for known visual references
Plane-less
Yes, it is known as the "red and white radio mast". I regularly listen to Special Rules West frequency at home, and know the radio calls for the reference points pretty well.anthonyhugo wrote:Hi I guess so check on the map it's in orange "Microwave Tower" east of HartiesD2O wrote:Are you referring to the SRW red and white radio mast reporting point at Harties?anthonyhugo wrote:Oh and if someone has the exact coords of the "Microwave Tower" north of "Gerotek Test Track" that would be great
HBV, Ernie Els Golf Estate, and Attridgeville Quarry are also reference points regularly called.
Plane-less
Thanks yeah I've been using Google Earth like crazy but struggling with some:
- "Silver Ball"
Btw what's "HBV" and is "Atteridgeville Quarry" = "Quarry Erasmia" on the SR map?
- "Silver Ball"
Anthony Hugo
Crosswinds
Crosswinds
OK found the tower: 25°41'21.01"S 27°59'1.94"E
Anthony Hugo
Crosswinds
Crosswinds
HBV is a nav beacon which VFR pilots also use as a VRP. Atteridgeville Quarry is the same as indicated on the SR map.anthonyhugo wrote:Thanks yeah I've been using Google Earth like crazy but struggling with some:
- "Silver Ball"
- "Highway Junction" - checking
- "Silver Ball" - checking
- "Hartebeeshoek Tracking Station" 25⁰ 53' 23.25"S 27⁰ 41' 07.38"E
- "Rail/Road Bridge" 25⁰ 54' 35.00"S 28⁰ 31' 30.00 E
Plane-less
Thanks! Got Silver Ball: 26°15'24.47"S 28° 4'53.82"E
Just missing:
- "Ga-Rankuwa Station" ---> 25°37'10.62"S 27°59'30.39"E
- "Rosslyn Station" ---> 25°38'15.96"S 28° 5'42.68"E
Just missing:
Anthony Hugo
Crosswinds
Crosswinds
- Tribal Croc
anthonyhugo wrote:
Just missing:
Thanks!Tribal Croc wrote:anthonyhugo wrote:
Just missing:
Anthony Hugo
Crosswinds
Crosswinds
Users browsing this forum: No registered users and 91 guests
