Good day to All,
Do anyone know where to buy foam or rubber sleeves for Trike
flying bar ?
Safe Flying !
Thomas
Foam or rubber sleeves for flying bar
Re: Foam or rubber sleeves for flying bar
Thomas,
They are called bar mitts.
Proper mitts are made from neoprene. I am sure Jenya makes them ("aerossa" on this forum).
I know some cyclists have also started using them but not sure if it will fit on a control bar.
Roel
Roel
Roel Jansen
ZU-IAR powered by BMW 1200
Icarus in JHB.
Thank you for replies !
I am actually looking for the sleeves that go around
the actual flying bar. Rubber or foam grip to prevent
hands slipping on bar.
Kind regards
Thomas
Kind regards
Thomas
- Barberton Sparkie
- Solo cross country
I use "Heat Shrink" that we as electricians use to isolate electrical cables. Get them in different colours, red,white, blue, yellow and black and in different sizes. Buy it one size bigger than what your flying bar diameter is slip it over and then I use my wives hair drier to crimp/shrink it on. Buy them from local electrical suppliers like Voltex or ACDC.
The electrical farmer that flies.
ZU-DEX
ZS-WOE
ZU-CCR
ZU-EKP
ZU-DEX
ZS-WOE
ZU-CCR
ZU-EKP
Slim plan!Barberton Sparkie wrote:I use "Heat Shrink" that we as electricians use to isolate electrical cables. Get them in different colours, red,white, blue, yellow and black and in different sizes. Buy it one size bigger than what your flying bar diameter is slip it over and then I use my wives hair drier to crimp/shrink it on. Buy them from local electrical suppliers like Voltex or ACDC.
- Tumbleweed
Go to Sportsman's warehouse and buy the cricket bat handle colour of your choice. Apply thin layer of Sunlight dishwasher to apply and should replace within 40 min. they only last about 2 years though.
Thanks to all for response.
Think both heat shrink and bat handle grips
will work.
On my way to Sportman's Warehouse.
Kind regards
Thomas
will work.
Kind regards
Thomas
- Madman
- The Boss
I have the tennis bat handle grips...very lekka
