Revmaster R2300 direct-drive
Postby Jean Crous » Mon Jul 06, 2015 9:38 pm
This 85HP engine is still the best "bang-for-buck" in it`s class. Installed weight is 80kg, dual 20 amp alternators (not belt driven), dual CDi ignition which is self energising ie: the engine can run without a battery. Cockpit controlled mixture via an injector body,( no conventional carburettor with float ). Oil cooler and Stainless steel exhaust included , and also air filter and carb-heat system.
Direct-drive, 4 cylinder, air cooled , horizontally opposed.(This is NOT a VW engine).
All Revmaster R2300 engines are factory assembled, factory test run for 2 hours before shipping. All engines undergo a Dynometer test run to ensure it delivers the rated 85HP at 3200 RPM.
The dyno test is done at 3600 foot above sea level.
The propeller we suggest is a 64 x 34 two blade P-Prop.
Pricing is exchange rate dependent and will include shipping and VAT.
Contact the local agent:
Jean Crous at 072 6716 240 , or 028 572 1566 during office hours.
E-mail aerokits99@gmail.com
What happens to one does not matter, how one deals with it does.
Bushbaby S/n 002 (Taildragger)
Powered by Revmaster R2300 direct-drive
ZU-ANI
Re: Revmaster R2300 direct-drive
Postby Jean Crous » Sun Jun 04, 2017 12:02 pm
With the USD to the ZAR at R12:82 , this engine landed here with all fees paid will cost R168 815.66. This includes the 4into1 Stainless steel exhaust system , and the alternate air supply with filter. 8)
ZU-ANI
Postby Jean Crous » Tue Sep 05, 2017 4:30 pm
The Revmaster in my Bushbaby performs very well indeed vhpy
Flying from 400ft ASL at Swellendam on 26deg celcius day with myself 98kg and 75L fuel, I get 1100foot per minute climb at 75mph. My Bushbaby has a clipped wing , so the standard wing should do better. At 3050RPM my Asi reads 118mph. My Asi is not a chinese one, it is certified and was checked by Aircraft Instruments CT. :mrgreen:
At a RPM of 2550 the speed returned is 93mph vhpy I use a 64x34 P-prop.
072 6716 240
ZU-ANI
Scorpio
Postby Scorpio » Mon Sep 11, 2017 8:01 pm
Hi Jean, plaas `n fototjie of twee van daai Bushbaby, sal graag wil sien.
ek is self besig met een puff
Kobus..~ Steelpoort Hillbillies s023 ~
Postby Jean Crous » Tue Sep 12, 2017 6:51 pm
Ek maak so vhpy
ZU-ANI
Postby Jean Crous » Tue Sep 12, 2017 7:23 pm
This is what she looks like vhpy
ZU-ANI
