VW 2.1 L aircraft engine**SOLD**
Postby Jean Crous » Tue Apr 23, 2019 10:00 am
I removed a VwW 2.1Litre engine from my personal Cubby . The engine has a belt reduction drive with it. This engine is still new with only 30 hours on it. No second hand parts, all new parts cranck case , heads, pistons and sleeves, oil pump etc etc.This engine case has a spin-on oil filter.
R45k takes it.
It will work in a wide variety of airframes.
Contact me : Jean Crous 072 6716 240.
PS : this is not a type 4 engine.
johannsc
Re: VW 2.1 L aircraft engine
Postby johannsc » Tue Apr 23, 2019 10:14 pm
Fuel injection or carb ?
CR Tech
Postby CR Tech » Wed Apr 24, 2019 8:02 am
R45k takes it.
Hi Jean, how come you mention it is not a type 4 ? Is you're engine a better option than the type 4 or the other way around ?
I know you don't like to degrade any item so may be challenging to answer but I'm very interested to know why you highlighted that fact. Many thanks
Postby Jean Crous » Wed Apr 24, 2019 8:02 pm
R45k takes it.
Hi CR, the type 4 engines had cylinder head problems on some models, and parts for them are not as plentyfull as the type 1. There were many more type 1 engines made than type 4. Also the type 1 is lighter because it has a magnesium engine case, whereas the type 4 has an aluminium case, making it heavier.The type 1 is also more well known for being converted to aviation use.
Jean
Postby Jean Crous » Wed Apr 24, 2019 8:04 pm
I have both options available. It was originally run with the Fuel injection, we changed it to a carb to save weight.
Jean.
CR Tech
Postby CR Tech » Thu Apr 25, 2019 8:15 am
R45k takes it.
Jean
I see , thanks
Users browsing this forum: No registered users and 96 guests
