I have a Rotax 503 Dual Carb Dual ignition complete engine for sale. This engine was running on my microlight and has been regularly serviced and recently dechoked and overhauled. All log books are up to date and available.
Engine hours - 350hours
Reason for selling: I upgraded to a 582
Included:
-Engine
-Ignition system, both mags with rectifier
-Rotax B gearbox
-Carburettors
-Air filters
-Throttle and choke cables
-Complete exhaust system.
-Fuel pump
This engine had a basic overhaul just before I took it out by a qualified Rotax AP. All work logged. 0 Hours since this major service.
Work done:
-New piston rings - run in procedure as per Rotax
-Carbs overhauled with new seals, jets, needle jets and needles
-Throttle cables services and calibrated
-New gearbox oil
-Timing done and mags serviced
-Pull start recoil stripped and serviced
-New spark plugs
Price R15 000.00 (no VAT)
Warren
Zero723400330
SOLD - Rotax 503 Dual Carb Dual Ignition Engine with Gearbox
Re: Rotax 503 Dual Carb Dual Ignition Engine with Gearbox
I forgot to add that the fuel pump is included.
