I removed from my plane as no place to mount without effect to airflow and causing tail to be in turbulent condition constantly.
Unit is in perfect working order.
I just have no use for it at this time.
Perfect for trikes
Make me an offer.
BRS Chute for sale
- Location: Circus Airfield - 2 miles north of Henley on Klip
BRS Chute for sale
- IMG_4763.JPG (30.63 KiB) Viewed 2346 times
- IMG_4764.JPG (30.72 KiB) Viewed 2346 times
- IMG_4765.JPG (31.32 KiB) Viewed 2346 times
- IMG_4766.JPG (31.72 KiB) Viewed 2346 times
- John.com
Re: BRS Chute for sale
Do you have a picture?
Also, what is the repack date?
John Comley
Magaliesberg, South Africa
I'll take pictures and advise repack date when at the field on Thursday
WEEKEND BUMP
- John.com
gavinwolff wrote:WEEKEND BUMP
Hi Gavin, I cannot read the repack date from the photo.
Is it 'March 2014', so in the past?
Thanks, John
John Comley
That is correct John
Hi Gavinwolff, I can not make out the model, max all up weight or max opening speed from the photos. Please let me know. Thanks.
Certainly
Popping out to the field shortly to change battery and will check
Its a model 345
Has a table on it reading from 160kmh to 260kmh
Max TO weight from 270kg to 560kg
max sink ration 6.4
Certification ZA-2LAA CS
Hope that helps?
max sink ration 6.4
Hope that helps?
