582 Short block spares and some 503 spares
The 582 spares was stripped off motor with approx. 150 hours. Logbook as proof available.
Blue top head (Sold)
2 x Cylinders R3000
Crank case R2500
2 x 54 Bing Carbs (Sold)
90 Deg exhaust with manifold (Sold)
1 X Ducati coil (Sold)
NC Hub and 2 X blades for E gearbox pusher configuration. R2000
E gear box (Sold)
582 Crank (150 hours). need to change outer bearings (was exposed to water for a short while) Checked clearances. In Spec. R3000
Stator Coil (Sold)
3 Blade Ivo prop for 503 Pusher configuration in reasonable condition (Sold)
E gear box (Sold)
Photos to follow
Tel 082 Eight Zero zero 6026
582 and 503 Spares for sale PRICES REDUCED
- Jakes Botha
- Ready for the first flight
- Jakes Botha
Re: 582 Spares and Hornet trike for sale
hi Jakes, stel in ebox belang. prys?
- Jakes Botha
Het jou sms gestuur
Re: 582 and 503 Spares for sale
Dankie Jakes .
Jean.
Jean.
- Jakes Botha
Re: 582 and 503 Spares for sale PRICES REDUCED
Hi there,
I would like to buy the oil and water pump shaft plus the water pump unit complete with impeller thats in the casing, would you sell it to me and if so how much would you want for it ?
Kind Regards,
Lionel ---- Phone 0837087601
Kind Regards,
- Emiel Thysse
- Got my wings at last
Jakes. Het jy nie dalk enige flight instruments nie?
Emiel Thysse
- Leprachaun
Hi Jakes het jy nog die vibration damper , Leprachaun 0825688635
- Jakes Botha
Hi Emiel,
Ongelukkig geen instrumente.
Groete
Groete
