Selling composite propellers
Re: Selling composite propellers
Propeller R-31-1400 for AIXRO XF40
Hi Meglin, what will a prop similar to a Warpdrive 3 blade lefthand 72"
for rotax 582 cost? any idea for the cost to South Africa...
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Hello Scorpio!
Specify the flight speed and gear ratio of the gearbox. This diameter can only be used at very high gear ratios.
The propeller was sent to South Africa without problems. Airmail is $ 70.
Hi Meglin, Gear ratio= 3.47
VNE of aircraft =125mph
cruise =± 85mph. Can you post a picture of the propellor..
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Hello Scorpio!
For such speeds and gear ratio, we recommend a propeller diameter of 1750 mm.
The best option is saber-like blades. They are the most quiet and effective. But straight blades are also permissible - they are cheaper, the quality of manufacturing is the same.
The saber-shaped propeller costs 610 euros, direct - 525 euros. Plus delivery costs 70.
Photos of both options can be seen on my website.
R-106-1750
- IMG_0559---.JPG (32.66 KiB) Viewed 13741 times
There was a new blade - elliptical. The diameter of the propeller is 1740 or 1760 mm, depending on the type of hub.
R-106-1750 vor G-13BB Kolb Mark-3
Hi Vladimir.
What aircraft is in the picture? The small white one with the AIXRO XF40 engine. Looks amazing. The prop looks as if it is to long for a tail dragger.
Freddie
Freddie
I congratulate everyone on the New Year!
We begin the production of variable pitch propellers. So far only for Rotax engines. So far, only a large diameter - 1900 mm.
Hi Vlad, I got an Aero prop that's delaminating, where can I take it to, to recondition here in South Africa.
contact me on 0832295310
It's better to write me an e-mail. I use a translator.
More Foto
More Foto
- 06270003юар--.JPG (68.69 KiB) Viewed 13199 times
Users browsing this forum: No registered users and 53 guests
