Duc Windspoon 2 Blade Carbon composite prop, with extra 3 blade hub and extra blade.
R16 000 negotiable
Contact Danie on 083 966 1607
DUC Windspoon 2/3 Blade Prop for Sale
Re: DUC Windspoon 2/3 Blade Prop for Sale
Bump
Owner prepared to consider reasonable offers
hallo.for what motor?Puller or pusher?
Can be used on 912 in pusher configuration (ie Pegasus GT 450 etc. )and 582 puller configuration (ie Cheetah, Kitfox etc with 582 engines)
It is also used on certain Gyro's
Was mounted on the Oribi with 582 engine in 2 blade puller config
Owner upgraded the Oribi to 912' but had to get a prop for 912 puller
Owner is prepared to go as low as R10 000
Please make a reasonable offer
What is the size of this prop..in inches?
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Bump
Any reasonable offer will be considered
