Hi guys, can the experts please tell me what this will mean for my trike that was manufactured in 1999 & who will do these inspections (& cost)?
Thanks!
CAA Directive - RSA PAD No: 13-002
Anthony Hugo
Crosswinds
Crosswinds
Re: CAA Directive - RSA PAD No: 13-002
It seems airframe inspections become due at 25 years (2024). Engine will be timex every 12 years - so it will require an overhaul.
Just another attempt by CAA to make blanket regulations that further push up the price of GA and thus put another nail in the coffin...
You cant make one rule to suit all aircraft...this will affect TCA's mainly as most of them are over 25 years old.
Only the manufacturers of an aircraft should be dictating when, how, and why inspections like this should be carried out on their relavant aircraft. All of which must be based on sound data and visible stats.
The CAA has no stats...and structural failure makes up a pittence of known aircraft accidents.
Me thinks a few AMO's got together and convinced the powers that be that their expensive equipment needs more work!
I highly doubt this one will get through...it affects way too many pilots and would not be good for anyone in my opinion.
The ARO's have been asked for comment...., the EXCO is waiting for further information as to the implications on NTCA's. Rowena will make representations to AeCSA from Misasa's side, so please forward your Comments to her asap.
That's why we are members at MISASABundy wrote:Just another attempt by CAA to make blanket regulations that further push up the price of GA and thus put another nail in the coffin...
- Signed up at flight school
Howzit,
This is probably not an issue for Aquila's, I do not know about other makes
CAA Document
2. Frequency of inspections:
2.1 The appropriate visual and if required NDT method of inspection is to be performed at twenty five years from date of manufacture on aircraft in normal categories. This only applies to aircraft that does not have a continued airworthiness program or aging aircraft program as mentioned above.
Aquila Manual
After the first 1000 hours the entire undercarriage and wing must be stripped down for a complete inspection of every part.
There is also a table showing the retirement life of critical parts some starting at from 1000 hours.
Going by the Aquila manual there is an aging aircraft inspection and parts replacement recommended program already in place.
CAA Document
Aquila Manual
