windlass trike SOLD
george wetselaar
windlass trike SOLD
Postby george wetselaar » Sun Dec 10, 2017 3:04 pm
serial no ; WL 96
reg no ; ZS WBO
engine ; 503 dcdi 10 hours smoh
prop ; p prop 10 hours smoh
wing ; original
price ; R25000.00
e mail ; mondial8@telkomsa.net
cell ; 072 6685 345
the trike comes on a liecenced roadworthy trailer
Last edited by george wetselaar on Sat Dec 16, 2017 5:07 pm, edited 1 time in total.
flyingboat
Re: windlass trike
Postby flyingboat » Sun Dec 10, 2017 6:42 pm
Where is the trike? Current Airworthy cert? Total hours on engine, wing and undercarriage? Cheers
george wetselaar
Re: windlass trike
Postby george wetselaar » Sun Dec 10, 2017 7:52 pm
the trike is at iswepe where i stay, it does not have ATF
total hours on motor unknown, it used to have a single ignition motor on, i then bought a dcdi motor from a member of this forum . stripped it down , checked the crank, rebored the cylinders to 1st over size using genuine rotax parts , and 1 ignition coil all from rotax [ invoices avaiable as proof ] i am the second owner of the trike,i have had it 20 years. the 1st owner kept no records however i donot believe he flew it much. i have flown 180 hours in total on the wing and undercarriage, i will send a detailed set of pictures to you , if intreasted let me have your e mail adress i have not flown it since the engine swap as there is no airfield in my area where i had to relocate to, i do however take it out the garage once a month and start it up , and run it for about 15 minites then put it away again, have being doing this for the last 2 years since the engine swap.
BUKS VAN NIEKERK
Re: windlass trike
Postby BUKS VAN NIEKERK » Thu Dec 14, 2017 11:33 am
hi George,
iam interested, please tell me
1) is the wing Dacron still good, or needs to be replaced
2)electric start / pull
3) when did the ATF expired (^^)
Regte manne skiet nie renosters om n horing te kry
george wetselaar
Re: windlass trike
Postby george wetselaar » Sat Dec 16, 2017 5:03 pm
SOLD
