2014 Model Carl Babst Raven TD for sale. Aircraft is brand new , can be flown with LSA license and packed with features such as EFIS, AoA, etc. (excl transponder), autopilot wiring already installed, just need two MGL servos. Airframe professionally built by the kit manufacturer Carl Babst. The aircraft is in pristine condition and a lot of effort and attention to detail went into building the best looking and performing Raven in the country.
Aircraft specs are:
- Airframe: ~50hrs, All aluminium construction
- Engine: Rotax 912 ULS 100 HP ~550hrs
- Brand new 72x57 fixed pitch P-Prop
- MGL Stratomaster Enigma Colour screen EFIS with attitude sensor, EMS, RDAC X (MP) etc.
- Dynon pitot tube with AoA port and complete with MGL EFIS AoA indication
- MGL V6 VHF transceiver and aircraft antenna
- Garmin Aera 500 GPS with AirGizmo panel dock
- Ray Allen Electric Elevator trim
- LED Strobe lights fitted in wingtips
- Circuit breakers for electrical distribution
- Fuel flow and tank level calculation
- GROVE aluminium landing gear spring blade with gundrilled brake lines
- Matco 6” wheels with hydraulic brakes
- 6 ply 600x6 Aero Trainer aircraft tyres
- Matco 8” tailwheel
- Interior lined with carpet
- Fiberglass elevator tips and wing root fairings
- autopilot wiring already installed, just need two MGL servos
Performance specs are:
- Stall: 45mph
- Rate of climb: 1300 fpm at sea level
- Cruise: 100mph @ 4800rpm, 110mph@5000rpm, 17lph fuel burn
- Max speed: 125mph@ 5500rpm
- Vne: 140mph
The aircraft is a dream to fly and friendly ground handling. It has a lot of features, including AoA indication, fuel calculation and fuel flow, flight routes setup, wingtip LED strobes, hydraulic brakes and 6 ply aircraft tyres, GROVE landing gear, etc... The list goes on.
All logbooks are up to date and the aircraft have a valid ATF.
Asking price R340K . Please PM me if interested or email induna(dot)za(at)gmail(dot)com. Aircraft located in Saldanha.
Reason for sale: buying another kit
Images and video can be found http://www.avcom.co.za/phpBB3/viewtopic ... 2&t=156063
Jacques van der Westhuizen
***Raven ZU-INJ***
- Induna
- Nothing beats flying
***Raven ZU-INJ***
ZU-RHT | Magni M18 Spartan
Re: ***2014 Carl Babst Raven ZU-INJ***
Nou wat nou dalk iets anders waarna jy kyk (RV ):?:
- Induna
Goose wrote:Nou wat nou dalk iets anders waarna jy kyk (RV ):?:
- Grobbie007
- Solo cross country
Eendag as ek groot is.....
- Induna
nou maar toe... gesels met my...??Grobbie007 wrote:Eendag as ek groot is.....
- Grobbie007
Haha.....as ek GROOT is !
- Induna
Re: ***Raven ZU-INJ - R400k neg***
Hi everyone,
still available. Price and specs updated...
Jacques
Jacques
Middag oom. Hoe gaan dit. Kan ek dalk groot asb oom se nr kry in verband met die horizon se vensters en deure. Wil kyk of ons nie dalk iets kan uitwerk om hulle hier by my te kry nie.
Groete
Divan
Groete
Divan
Users browsing this forum: No registered users and 37 guests
