NAMIBIA - CHALLENGER SHORTWING( PRICE REDUCED)
Re: NAMIBIA - CHALLENGER SHORTWING
The kit comes with the belt system. It is a design thing.hummer wrote: I see it has s belt drive , any reason for this opposed to a gearbox, Does it have electric starter.
It also absorb a lot off vibration.
Re: NAMIBIA - CHALLENGER SHORTWING( PRICE REDUCED)
Thanks for answering Pierre.
I had a look this past weekend comparing my Aviatika against the Challenger - propeller wise
If you look at the photos of the Chally the engine is mounted upside down ( plugs at bottom ) which bring the position of the engine
at the back of the aft seat - and not above the head of the passenger seat.
This leaves very little room from the engine to the fuselage running to the tail feathers and would leave you with a very short propeller.
By using the belt drive the offset is upwards and give more space for a more sufficient propeller .
I think this also add to the nice crisp handling of the aircraft as all the weight from pilot , passenger and engine is in one straight line
and not the engine weight and drag sitting on top of the passenger's head. As Pierre said a design thing.
With this small engine she easily run from 85 to 90 mph at sea level and had to be throttled back although the short wing's VNE is 120 mph.
Through the last 40 hours i have flown the challenger we never needed to adjust or tighten the belt and all is still in very good condition.
Personally owning a gearbox driven 582 Rotax or the belt drive of the Challenger there is no difference.
The challenger has a 60 inch propeller and the aviatika is more like around 70 inches
Johan de Wet
Johan de Wet
Aircraft is actually standing now that my son is away.
I am flying it about every second weekend for 20 min just to keep it going and clean
All authority to fly , radio licensing etc kept up to date.
Fortunately not a must sell situation for the very optimistic.
Only one pilot with two aircraft to fly ?
Johan
Johan
Aircraft standing now.
Regularly started and let run until temperatures is in green.
Further kept kleen
Looked after and still available
Johan
Further kept kleen
Johan
Dag Induna
Dankie vir die pm.
Ek gaan nie weg nie en jy het my telefoon nommer bo by die advertensie.
As jy Swakop toe kom skakel my net en ons gaan vlieg n draai.
Die woestyn lyk anders en baie mooi uit die lug
groete
Johan
Namibia
00264 81 124 8283
Dankie vir die pm.
groete
Johan
Namibia
00264 81 124 8283
- Induna
- Nothing beats flying
Hi Johan,
Dit klink baie belowend!! Julle Namibiers is baie gasvrye mense... Ek sal petrol saambring!
Jacques
Jacques
ZU-RHT | Magni M18 Spartan
Dag Jaques ( INDUNA )
PM my asb wanneer ongeveer julle hier in Swakop sal wees dat ons draai kan gaan vlieg.
Wil die naweek die Chally diens en nog n slag plaas toe gaan om te gaan jag.
Maar dit is veranderbaar want ek is my eie baas ( moenie dat my vrou dit hoor nie )
Nee spot net ek kan enige datum aanpas.
groete
Johan
00264 81 124 8283
groete
Johan
00264 81 124 8283
Aircraft being flown very little now
Need a new home.
Just been through inspection and authority to fly to be updated this week( paperwork )
New plugs , filterers etc as per manual required
Need a new home.
Het jy toe n koper gekry vir die chally meneer?
Users browsing this forum: No registered users and 56 guests
