Skyjeep CH 701 project for sale
coenvanwyk
Postby coenvanwyk » Wed Mar 26, 2014 9:44 pm
I regretfully have to put my Skyjeep project up for sale.
I bought the quick build kit from Zenith in 2006, basically for my son, who was then doing his apprenticeship in Port Alfred as Aircraft Sheetmetal worker. He built the basic parts, tail group and wings there, and then a skirt got in the way ...
I then brought the kit up to Pretoria and while the Defence Flying Club operated, completed the fuselage rear and cabin pan there.
We got kicked out there in 2012, and since then I have tried to find a place to build at home, but it just is not going to work out. At the same time I realised that I will not get a medical, and so I decided to give up the project and instead build a sailing boat.
The rudder, stabiliser (with vortex generators) and the wings are basically complete. Wingtips must be closed after all the other work is done. The rear fuselage and the fuselage pan is done. I have all the parts, but will have to look for them as they are a little spread out over the two garages.
I also have a panel radio (Icom), a transponder, airspeed indicator, non-sensitive altimeter, and antennas, as well as an in flight adjustable Ivoprop.
Is anyone interested?
Coen van Wyk
coenvanwyk @ gmail.com
Johnorr
Re: Skyjeep CH 701 project for sale
Postby Johnorr » Thu Mar 27, 2014 2:19 am
I am interested in that IVO prop will you sell the prop?
IceAge
Postby IceAge » Thu Mar 27, 2014 10:46 am
Coen,
Do you perhaps have pics of the completed bits?? Also could you indicate a ballpark number (read RRRRR) you had in mind?? Lastly what is required to complete the build apart from passion and hours???
Caught a dream............
Windlass Aquilla
Thunderbird MKII
Savannah VG
witwillem
Postby witwillem » Sat Mar 29, 2014 2:43 pm
Prys en fotos asb , tel nommer ekke stel belang witwillem
coenvanwyk
Postby coenvanwyk » Sun Apr 13, 2014 4:32 pm
Hi Willem, en ander belangstellendes,
Die hoof komponente is aanmekaar gesit en afgeteken: Agterste romp, Stertvlakke, firewall, vlerke, en kajuit pan. Alles is met strontium Chromate of ekwivalent gesprei om korrosie te verhoed. Die kit sluit alles in van die firewall af terug, asook 'n Icom IC-A200 paneel radio met antenna,'n Narco replacement transponder (sonder mounting tray) with antenna en herboude IImorrow encoder, 'n Falcon 0 tot 100 kts ASI, 'n UMA enkel wyser altimeter, 'n Flightcom 2 plek intercom, en 'n fibreglass nosecone vir 'n Rotax.Daar is ook 'n 72" in flight adjustable Ivoprop. Geen van die komponente is nog gebruik nie. Ek kyk na R 300 000, wat aankoopkoste, vervoer en inklaring, doeane ens, asook 'n regverdige verteenwoordiging van die werk tot dusver gedoen insluit.
Kontak my gerus op coenvanwyk @ gmail.com of 071 246 7222 na nege in die oggende.
Coen van Wyk
coenvanwyk
Postby coenvanwyk » Sun Apr 13, 2014 4:33 pm
Stuur e-pos adresse en ek stuur klompe foto's!
juangerrits
Postby juangerrits » Sun Apr 13, 2014 9:32 pm
Stuur asb fotos, gerritsjuan@gmail.com
Safe Flying
Juan
coenvanwyk
Postby coenvanwyk » Sat May 03, 2014 9:57 am
Still available, options expired.
How do I post a few pics?
Coen
Bushbabie
Postby Bushbabie » Tue May 06, 2014 5:49 pm
Mail the pictures to me and I will post for you.
lance.mcintosh@joshgen.org.za
Bushbabie
Postby Bushbabie » Tue May 06, 2014 10:40 pm
coenvanwyk
Postby coenvanwyk » Thu May 22, 2014 8:14 pm
Propellor sold, rest of the project is still available.
