Hi Greenman
Ive been there strongs with the rebuild and believe it or not the damage isnt as bad as it looks Will you be doing the repairs at home?
Cheers San
P.s. the Duck and myself have both done this to some extend call if you need assistance
oh 83 57zero seben 158
Reviving WHH
Re: Reviving WHH
- Greenman
- Signed up at flight school
Re: Reviving WHH
Yes San I will be repairing at home. I have a huge workspace as I stay on a smallholding and I built some mushroom houses that has not been used yet. I will surely knock on your door at some time to light the candle of knowledge.
Gunter, I cannot seem to open the last link. It keeps on giving me an "HTTP 404 Not Found" error. Could you help?
regards
Chris
regards
Chris
Re: Reviving WHH
Good luck with your rebuild Greenman! Wishing you buckets full of patience as well and much perserverance!
Re: Reviving WHH
Hi Greenman,
OK I cant attach the file here because it is too big.
It is situated in the Jodel group on Yahoo groups in the files area. so maybe join that group and then you can down load from there directly onto your computer. It is called
"AC 43-13 Chapter 1.pdf "
http://groups.yahoo.com/group/jodel/
Alternatvely give me your e-mail address via PM and I will mail the PDF file to you.
Kind regards,
Gunter Rostek.
Kind regards,
Gunter Rostek.
- Greenman
Re: Reviving Super Koala WHH
I have started to strip the wing and it looks very bad. Considering having a braai with it instead. Is there anyone with plans for this aircraft that might consider selling me some copies. It would be bad to try and stick new wood into the aircraft without having at least some sort of an idea about the plans, not so?
Re: Reviving WHH
Hi Greenman,
Plans are a definite advantage, here is a link for getting them. Expensive though.
http://www.fisherflying.com/fleet/pricelist/
Maybe you will be offered a set locally at a much better price.
Good luck.
Gunter Rostek
Good luck.
Gunter Rostek
Users browsing this forum: No registered users and 41 guests
