Page 3 of 5
Re: PERIS JN-1
Posted: Sat Jul 27, 2013 5:52 pm
by Bushbabie
Foam blocks glued over the engine. Sanding, sanding, sanding, you know the story.
Re: PERIS JN-1
Posted: Sun Jul 28, 2013 3:13 pm
by Jean Crous
Hi Lance, that looks good. What sort of foam did you use ?
Re: PERIS JN-1
Posted: Mon Sep 16, 2013 9:33 pm
by Bushbabie
Been slow this winter. Cape weather not conducive to fibre glassing or painting AND we bought Cubby ZU DWY!
Have however completed the wiring, installed the engine and test run it!
Re: PERIS JN-1
Posted: Mon Sep 16, 2013 9:35 pm
by Bushbabie
YOU TUBE of first engine test run
http://youtu.be/OjOI4phCUIU
Re: PERIS JN-1
Posted: Tue Oct 15, 2013 11:25 am
by Bushbabie
Been slow an this project since enjoying the Cubby.
However undercarriage is complete at last and fitted. First rollout.
Re: PERIS JN-1
Posted: Sat Nov 02, 2013 10:54 am
by Bushbabie
Made a split mould from the plug. Came out with same imperfections which I will sand out later. Very happy with the results.
Re: PERIS JN-1
Posted: Mon Nov 18, 2013 1:06 pm
by Bushbabie
Finally finished the cowling
Re: PERIS JN-1
Posted: Wed Nov 20, 2013 11:51 am
by CR Tech
I asked about this on the other forum but maybe best to continue here.
So I see that it is built from plans thats great and just what Im looking for. But
Are there other type currently flying in SA ?
Who did you get as AP on your project ?
Instructors for type conversion ?
I think this is such a sexy little number
CRT
Re: PERIS JN-1
Posted: Sun Nov 24, 2013 10:09 pm
by Bushbabie
Cowling fitted, Exhaust fitted, Fitted the prop which we are using for testing. Engine running soooo sweet.
Re: PERIS JN-1
Posted: Sun Jan 19, 2014 9:01 pm
by Bushbabie
Did some engine runs. All is running smoothly.
http://www.youtube.com/watch?v=BS7wtIRK7q8
Re: PERIS JN-1
Posted: Mon Jan 20, 2014 8:48 pm
by avgas
well done
Re: PERIS JN-1
Posted: Fri Feb 28, 2014 8:06 am
by Boet
So.......?? When is the first flight??
Re: PERIS JN-1
Posted: Mon Mar 10, 2014 8:50 pm
by Bushbabie
- Rudder
- CAM00012.jpg (26.68 KiB) Viewed 7661 times
Next inspection done. Engine installation, electrical installation, brakes, tail planes, elevators, rudder, control cables, trim tab, header tank and fuel lines all signed off.
Re: PERIS JN-1
Posted: Mon Mar 17, 2014 9:20 am
by Henni
Hi Lance,
Apologies for being upfront. I intend to mount my engine much the same you did, however I'm completely out of scrap aircraft grade material as I did not think I'll ever build again.
Would you please be so kind as to inform me where you purchased the aluminium, 4130 tubing and engine vibration rubbers from. Will save me a lot of time.
Re: PERIS JN-1
Posted: Tue Mar 18, 2014 9:16 am
by Bushbabie
I took over the project in it's early stages and all necessary aluminium and some 4130 tubing came with it. The engine vibration rubbers were purchased with the engine. Further 4130 tubing I purchased from MS Engineering Cape Town.
