Hi All
Just some pic s on Aquilla frame Rebuild also need spares for Aquilla 1 will add as i go along if you have some laying around give a shout new or used
Aquilla 1 Frame Rebuild ZU-???
- Reuben zu-ccm
- Learning to fly
- Need Rubber Boots
- Front Rubber boot.jpg (31.82 KiB) Viewed 3217 times
- Need new Rear axels left and RIght
- TEST Aquilla Frame.jpg (33.81 KiB) Viewed 3217 times
- Back shock Spats
- Pics frames 1.jpg (29.25 KiB) Viewed 3212 times
- New Wheels
- Pics frames 2.jpg (29.44 KiB) Viewed 3212 times
- Air Hog
Re: Aquilla 1 Frame Rebuild ZU-???
Hi Reuben
Julle moet vinger trek, ons mis julle by Kroon!
- Reuben zu-ccm
- Learning to fly
Hi johan
Ek sal seker terug wees by die middle van june is besig met Aquilla en Cosmos met jenya vlerk het weer toets gevlieg en is weer reg om te vlieg hoe lyk die hanger spasie? .?
groete
Reuben
groete
Reuben
Hi Reuben is dit hierdie trike wat laas week daar by Rhino was?
Anthony Hugo
Crosswinds
Crosswinds
- Reuben zu-ccm
- Learning to fly
Re: Aquilla 1 Frame Rebuild ZU-BGE
Hi Antony
Yes fitted my wing today and hope to do high speed runway testing for a hour asp and then to the skies for me
Garfield
Garfield
- bobthebuilder
Hi Reuben,
Your trike is looking great. Very neat and tidy.
Just an observation ......
What grade of bolts did you use on the undercart? I'm not sure that common hardware variety grade 8.8 bolts are suitable. They may be, but rather ask your AP to check them.
The purists will tell you that the bolts are also too long.
Best regards,
Byron
Best regards,
Byron
Byron Kirkland
8.8 grade bolt are more than strong enough. Just make sure that the thread is not "inside" whatever you are bolting together. The grip length, ie, the shank of the bolt measured from underneath the head of the bolt, to where the thread starts, MUST portrude slightly out of what you are bolting together, so add a washer or two. OK, the threaded part is always hopelessly to long, and looks crappy, but if you cut it shorter, PAINT tha damn thing, otherwise it will rust. Your workmanship looks very neat!!
- Reuben zu-ccm
- Learning to fly
Thanks you guys
Rebuild commpleted and flying ZU-BGE
Reuben
Reuben
Users browsing this forum: No registered users and 33 guests
