Page 4 of 8
Re: Bushbaby Explorer 153
Posted: Wed Jan 25, 2012 2:17 pm
by JuanMarais
Het toe sommer my eerste Solo ook agter die rug....
Posted: Wed Jan 25, 2012 2:32 pm
by KFA
Posted: Fri Jan 27, 2012 1:19 pm
by ppakotze
Gelluk, maar daai solo een se wiel sit nie op dieselfde plek as joune nie.
P.
Posted: Sun Jan 29, 2012 11:09 pm
by AndyCAP
Congrats on your first solo Juan! There is only one first time
Regarding the windows. Firstly its generally a good idea not to leave right angle corners in your cutouts in aluminium. Rather leave a radius on each corner to prevent stress concentrations in the corners creating cracks in the Aluminium over time. The easiest is actually to make the short side of the rectangle of the cutout circular so the shape is that of an athletics track. This also looks much better than a rectangular cutout
Secondly I think it KFA was referring to putting windows in the roof (I.e. In line with the centre of the wing's chord. It should be above and slightly in front of your head so that you can look through that section and see the runway when turning from base onto final approach.
Go have a look at OupaG's build thread of the Safari nothing on that plane has happened by chance! You can learn a lot from him!
Also speak to Boet he builds BB's in his sleep!
Good luck with the build you are making good progress
Posted: Mon Jan 30, 2012 12:26 pm
by JuanMarais
Thanks for the advise. I have 20 diameter holes drilled before starting the cut outs on the windows. So at least I got a radius on each corner. The windows in the roof if will have to make later as I'm leaving for America again tomorrow. See you all soon.
Posted: Mon Mar 12, 2012 5:19 pm
by JuanMarais
Started covering. Rudder and elevator done. Flapperon's pre-fitted and turtle deck cut outs done. Wings also ready for covering.
Posted: Mon Mar 12, 2012 9:26 pm
by mic
the rudder and elevators are the hardest to cover 'cos of the tight corners, the rest is easier....except maybe the dreaded fuselage to fin corner.
Posted: Mon Mar 12, 2012 9:31 pm
by Boet
mic wrote:the rudder and elevators are the hardest to cover 'cos of the tight corners, the rest is easier....except maybe the dreaded fuselage to fin inside corner.
Die "dreaded fus to fin inside corner is maklik"
. Praat met my! Ek het "how to" fotos.
Posted: Tue Mar 13, 2012 5:57 pm
by JuanMarais
dan moet jy stuur.
juan.marais@yahoo.com
Het goed reggekom met die elevator en rudder, so hoop die res is soet koek. Net kak baie strips om te plak met elevator en rudder
Posted: Tue Mar 13, 2012 6:27 pm
by Boet
Jy het e-pos. VOOR jy sukkel, praat asb.
Posted: Fri Mar 30, 2012 3:21 am
by JuanMarais
Wel, my speel tyd is alweer om en tyd om te gaan werk. Kon darem redelik progress maak met die covering. Het elevator, rudder en stabelizer voledig oor getrek. Altwee vlerke oor getrek en kry eerste coat en picking strips as ek terug in die land is. So volgende is die fuselage. Het ook drawing van die panel klaar, wag net vir die GPS om final laser cut te laat doen. So ek vorder so stadig maar seker. Jammer geen fotos nie, dis almal op my foon en het kabel vergeet.
Posted: Sun May 20, 2012 5:30 pm
by JuanMarais
Progress with the covering.
Posted: Sun May 20, 2012 5:31 pm
by JuanMarais
The wings
Posted: Sun May 20, 2012 5:33 pm
by JuanMarais
Basically finish with covering. Only few strips to be installed on fugelage and then the painting progress begin. Wings and loose parts already 4 coats Nitrade applied.
Posted: Sun May 20, 2012 9:22 pm
by Jean Crous
