For your sake I hope you are referring to the foam............justin.schoeman wrote:
Actually amazing what small irregularities and assymetries you can pick up by just running your hands over it!
Nice job so far the cowl looks great
Nope - this is a fresh kit from Carl...Aerosan wrote:Justin did you buy this of Ian
I will be taking a mold from this plug, so the mold will be available if anyone wants to make another 'scowl'... In fact, I would like it if it is reused - after the amount of blood, sweat and tears that went into it, it would be a shame to make just one!Niloc wrote:Hi Justin
Have you made a mould for this cowling, could you make another ?
Please contact me on 0824526576
The 'scowl' was completely unintentional. I simply started with a block, cut open the air inlets, and then cut everything back as sharply as possible, to clear as much material as possible, as far back as possible, form the prop disk (to improve prop efficiency on the short VW prop).Scotsman wrote:"scowl" could also be the brand name/short hand for Schoeman's Cowl....
Users browsing this forum: No registered users and 78 guests
