CH 701
Z-MRP
Re: CH 701
Postby Z-MRP » Thu Apr 06, 2017 4:15 pm
Hi Goose, yes am back building now that the broken leg is useable vhpy .I had a set back on the 4 fuel tanks which had to be redone with thicker material even thought I followed the plans.Wasted 2 sheets of 0.025 6061, any way tanks are now done and fitted. I hope to have the main spars inspected this weekend and then rivet the top skins onto the wings.Then the build gets exciting as will then try fit wings to fuselage set dihedral and fit and drill wing struts.
I will post some photos shortly of the wings once riveted closed and then some photos of the wings fitted to fuselage.
Goose
Re: CH 701
Postby Goose » Thu Apr 06, 2017 7:01 pm
Z-MRP it's good to hear you are still building. Every now and then there's a setback but you must keep going. It's always a achievement when the wings go on and it looks more and more like a real aircraft.
Z-MRP
Re: CH 701
Postby Z-MRP » Tue Apr 25, 2017 12:33 pm
97A Left wing upper skin riveted.jpg (20.02 KiB) Viewed 15630 times
97 Left wing tanks,wiring and pitot line fitted.jpg (20.9 KiB) Viewed 15630 times
Build update. Wing spars have been inspected and passed so a huge leap forward on the construction of the wings.Tanks fitted and plumbed in along with nav wiring and pitot tube tubing.
Busy working on closing up the wing tips along with a mod to fit a hatch in the wing tip panel to access nav wiring and create a small storage/baggage space.
Z-MRP
Re: CH 701
Postby Z-MRP » Mon May 08, 2017 11:46 am
97E Left wing tip storage hatch.jpg (19.68 KiB) Viewed 15559 times
97D left wing tip storage hatch.jpg (20.97 KiB) Viewed 15559 times
97B Left wing completed.jpg (34.06 KiB) Viewed 15559 times
Left wing completed as well as adding a storage hatch in the wing tip.
Z-MRP
Re: CH 701
Postby Z-MRP » Mon Jun 05, 2017 6:11 pm
Good progress this last weekend. Right hand wing closed up and riveting completed.Now to do the wing tip fitting and inspection hatch in the wing tip.
Z-MRP
Re: CH 701
Postby Z-MRP » Mon Jul 17, 2017 10:31 am
98 Fitting the wings.jpg (27.77 KiB) Viewed 15459 times
Wings are now fitted. Dihedral is set now to start making up the wing struts
Goose
Re: CH 701
Postby Goose » Sun Jul 23, 2017 8:34 am
Getting closer to the end of the building and even closer to flying (^^)
Z-MRP
Re: CH 701
Postby Z-MRP » Wed Oct 18, 2017 7:57 am
I am looking for the drawings to make up the radiator mounting brackets for my CH701.I am using the rotax ring mounting and unfortunetly my plans only show radiator mounting for the old style of engine mounting.Possibly this drawing would also be in the CH750 plans.
Thanks in advance
Goose
Re: CH 701
Postby Goose » Tue Mar 13, 2018 7:38 pm
Z-MRP you must be close to flying now :twisted:
Z-MRP
Re: CH 701
Postby Z-MRP » Thu Dec 20, 2018 5:52 pm
Hi Goose, build has progressed very well, little slow as I have been doing my CPL licence and IF rating.
Plane is 95% complete, last 5% of the build is taking the most time. All small fiddle work but getting there.Engine run up is done. MGL Efis unit powered up and tested.
Will try post a pic.
Goose
Re: CH 701
Postby Goose » Sun Mar 15, 2020 8:28 pm
Z-MRP the plane must be flying by now
Z-MRP
Re: CH 701
Postby Z-MRP » Tue Mar 17, 2020 5:29 pm
Hi Goose thanks for the follow up.Yes plane is complete and ready to start testing. I have been struggling for 2 months now to get the registration process completed.I am hoping in the next week or so to have satisfied the authorities documentation requirements.
I must apologize for not updating my build log just been ultra busy at work.
I will get some photos posted short
Z-MRP
Re: CH 701
Postby Z-MRP » Mon Jun 08, 2020 5:32 pm
Finally got the Certificate of Registration done. Hopefully we will be able to test fly it some day soon once covid19 madness is over.Plane has been waiting since January to test fly.
Z-MRP
Re: CH 701
Postby Z-MRP » Mon Jun 08, 2020 5:38 pm
JvTonder
Re: CH 701
Postby JvTonder » Tue Jun 09, 2020 9:37 am
Nice and congrats!
Users browsing this forum: No registered users and 102 guests
