Hi
Any one bussy building a tj5 gyro in south-africa?
Hennie
tj5 gyrocopter
JT 5
hy bedoel seker JT-5
Dit is 'n ontwerp van Jukka Tervamaki
Hy is die vader van die Magni's se ontwerp
ek het 'n volledige stel planne en wil eendag een bou
enkelsitplek het my afgesit sowel die onverkrygbaarheid van chromemoly
leon
leon
re
The Jukka Tervamaki is developed for a 1700 VW direct drive engine.
I would prefer a rotax 582 e box.
The problem with this is that you have to use a longer prop than the direct drive.
With a longer prop you need a longer mast and also need to move your engine higher.
This will have an effect on your thurstline that you need to adjust by making the tail section longer or moving the seat forward. This will have an effect on your centre of gravity.
By making all these adjustments you could end up with an unstable gyro or spend more on development than you would have paid for a brand new one.
Or alternatively contact Bennie for a VW engine !!
Users browsing this forum: No registered users and 32 guests
