Behind the times I seegertcoetzee wrote:Ah something a Jozi will not understand. This is Cape Town Time.. By the way Gert, I see on your track log that you have put in "UTC -2", we are UTC+2, 2hrs ahead of Grenwich.
Western Cape Airstrip Database..
- gertcoetzee
New farmroad usable as strip in Delta 200 (north eastern sector), length approx 300m with a bit of a curve in middle 25/07. No power lines, dam to the west.
See http://www.cvdm.co.za/zu-dve/20050922.jpg
or http://microlighters.co.za/viewtopic.php?t=298&start=60
S33 31 49.7 E18 37 11.4
- gertcoetzee
The farmstrip I have named Dieprivier, is actualle on the farm De Goede Ontmoeting and the name has been changed in the Western Cape file:
http://www.cvdm.co.za/zu-dve/Western%20Cape.gdb
Yesterday's strip (Skaapkraal) has been added.
- gertcoetzee
Stopped giving designations since I got my trues and magenetics mixed up. Someone else can probably tell us what the correct way of designating rw names is.
Yes, both Old Malmes and Dieprivierbrug have same bearing, suppose the magnetic bearing will be +2 (vs my numbers).
I have renamed the Dieprivierbrug waypoint to De Goete Ontmoeting which is the farms' name - it could have been Soete - will have a look when I go past again.
The Old Malmes strip is a crop strip and has the skeleton of a plane on the northern side. Will land and look soon.
- John Young
Morpheus is quite correct with "magnetic variation +/- 23 degrees".ACE wrote:I got into my GPS setup last night and found that it was set to "true North" so I reset it to Magnetic. The current magnetic deviation is 18degrees, a big difference to your heading isn't it
"Magnetic deviation" is a another story. This relates to the amount a compass is 'swung' by having metal objects located in the proximity. Consequently, marine vessels and certain aircraft have a "deviation card" which lists the magnetic deviation at selected headings for captain / pilot correction.
Looking forward to "kicking" my instructor off the back seat soon!
- John Young
Mmmmm ... Just read Morpheus' message again - this variation and deviation has tripped up many folk.
My understanding is;
Magnetic variation = difference between magnetic north and true north.
Magnetis deviation = difference between compass reading and the correct magnetic heading.
Someone correct me if I cocked-up.
PS: My instructor has got less than 5 days to keep his "a.se" warm on my back seat!
Yep, if you look at the aviation maps you will see the "variation" (thanks John) lines running across the map( these are dashed lines running across the map at an angle with "18deg W" written on it for example As you move south the variation increases. If you are using a map for navigation, you would use the value from the variation line closest to you, i.e from your current position the 18 deg variation line is just below you and the 17.5 is above but further away. You would use the 18deg for the calculation. The GPS does this all automatically.ACE wrote:My GPS automatically came up with 18 degrees would this be attributed to our different geographical locations
Here I get to quote myself, that's a first.ACE wrote:... The current magnetic deviation is 18degrees, ...
Wrong choice of words - I stand corrected. Even at the foot of the aeronautical maps it states the annual variation between true and magnetic north. It drifts as time goes by. Well spotted John and thanks.
.. now which was north again, oh that way..
A Smith & Wesson beats five Aces
- gertcoetzee
- gertcoetzee
