Let us revive this forum with some questions to keep us sharp...
Don't be shy to awnser.If your awnser is wrong,I'll give the right one,and explain ...
Any instructor can also place a question here,but must know the right awnser,and must give it at or before the next day.
Brain teazers
Brain teazers
Re: Brain teazers
Density altitude question:
Work out pressure altitude :Elevation is 4000',temperature is 28deg C,and the QNH is1030...
- Madman
Re: Brain teazers
- Looking at the sky
Re: Brain teazers
An aircraft standing on a conveyor belt the same length and with as a runway and the conveyor running the same speed as the wheels of the aircraft ,will the aircraft take flight ?
- Madman
Re: Brain teazers
Ryno Botma wrote: ↑Wed Jan 17, 2018 10:45 pmAn aircraft standing on a conveyor belt the same length and with as a runway and the conveyor running the same speed as the wheels of the aircraft ,will the aircraft take flight ?
No, the aircraft would need airspeed to take off, air over the wings
- Madman
Re: Brain teazers
If you smoked some weed before boarding a flight, the cruising altitude of the aircraft is now FL350, how high are you
Re: Brain teazers
As high as your imagination
- Madman
Re: Brain teazers
You were already at altitude before the plane took off
Users browsing this forum: No registered users and 63 guests
