Dear Fellow Aviators
I am pleased to announce the establishment of Aerospace WorX cc as a Volume Discounts Company (VDC) to market Sonex LLC products, which include the Sonex, Waiex, Xenos and the latest addition, Onex metal kit aircraft. Sonex LLC also manufactures the cost effective, but robust AeroVee 80hp engine, suitable for a wide range of kit aircraft manufactured in South Africa, at the fraction of the cost of other power plants.
These exiting aircraft models serve a wide spectrum of the Light Sport Aviation and Soaring community. All aircraft are rated for aerobatics. John Monnett, the founder of Sonex LLC, commented that not everyone is up for aerobatics, but it is good to know you have the strength built into your aircraft.
The VDC concept offers discounts on volume orders placed through Aerospace WorX cc that ship together. As from October 2012, Aerospace WorX cc will also offer builder assistance services to get you flying in the shortest possible timeframe. Existing Sonex/Waiex owners in South Africa may also benefit from Aerospace WorX cc‘s services when ordering sections or parts for their aircraft.
For more information on Sonex LLC’s models, visit http://www.sonexaircraft.com.
For further information on Aerospace WorX cc’s services, contact Neil Cooper on 083 294 3537.
(E-mail address and website information will be made available soon – watch this space!)
Neil Cooper
Aerospace WorX cc
SONEX, WAIEX, XENOS and ONEX @ Aerospace WorX cc
Re: SONEX, WAIEX, XENOS and ONEX @ Aerospace WorX cc
Where are you based? Up to this point, the only gripe I have had with the AeroVee, is the extreme cost of shipping spares from the manufacturer.
Based in Cape Town, Durbanville. Regarding the AeroVee engine and cost of parts, the whole idea is to save cost on volumes import. Depending on demand, one may at a later stage consider to keep parts in stock for the local market.
Let's see.
Let's see.
was on the brink of getting a onex, tell us more
Hi Neil, You may also want to register on Avcom. There are a couple of Sonex and Onex builders there, and there was a lot of interest expressed on the Onex thread.
Hi "Mic"
The concept is volume orders. If SA orders go through the VDC (Aerospace WorX), there is savings in shipment (more kits in a single container). There are some discounts from Sonex for SA orders that ship together. (Please note that there is no mark-up on any of the Sonex products by Aerospace WorX.) Dealing with a local company also save you the hassle of importation red-tape.
As mentioned before, as from October 2012, Aerospace WorX will offer professional builder assistance to clients to have any Sonex product in the air in less time. This includes the AeroVee engine.
PM or phone me if you need more information or costings for a complete Onex.
Thanks for the tip, Justin. I saw the thread and activity on Avcom. Just finalising a few things on my side and then wil post there as well.
Aerospace WorX cc is a distributer of the AeroVee engine. It is an economical and reliable alternative aviation engine that will reduce your fun flying and maintenace expenses significantly.
(Quoting Aeroconversions...) AeroVee is a "state of the art" VW based engine converted for sport aircraft. This system represents over 12 years of research, development, engineering,
and testing. Our design team has over 35 years of experience in pioneering, innovating and flying VW based engine conversions.
All our engines meet the highest quality standards. We machine components from solid billet,
whenever appropriate, providing you superb quality conversion parts ... the best ever produced!
AeroVee Features:
• Low profile design provides for low-drag, stream-lined cowl installations
• Optimized Custom Crankshaft
• New generation shrink fit prop hub with 6 prop drive bushings
• Unique "dual-plus" magnetron & solid state electronic ignition. (Two spark plugs per cylinder, only one moving part)
• Precision machined-from-billet accessory mounting plate
• Standard 20-amp alternator and regulator
• Light weight flywheel assembly
• AeroVee-specific Sky-Tec "Flyweight" geared starter
• 3-piece billeted intake manifold with stainless steel "V" tube
• ACV-C07 (32mm) Aerolnjector included
• All block-off plates included, laser-cut and anodized
• All necessary hardware
• AeroVee Engine Assembly DVD and Manuals
• Nikasil-Coated Aluminum Cylinder Upgrade Available: Save 9 Ibs!
AeroVee Specifications:
HP@ 3400 RPM: 80hp
Bore (mm): 92
Stroke (mm:) 82
Displacement (cc): 2180
Compression Ratio: 8.0:1 for 100ll or 7.0:1 for Auto fuel
Ignition: Dual Magneto & 12v. Electronic
Firing Order: 1432
Propeller Drive: 1.1
Throttle Body: Aerolnjector ACV-C07
Starter: Geared
Alternator Output: 20 Amp
Length (hub face-mount): 19.5"
Length (total): 25"
Width: 30"
Height: 14"
Prop Hole Pattern: Qty 6@ 4" Center
Weight (installed): 151-160 Ibs (excluding exhaust)
Over 35 Years of design and development experience has produced this quality, inexpensive, easy to build and maintain Kit Aircraft Engine!
Bringing Affordable Power to the Sport Pilot
AeroVee Features:
HP@ 3400 RPM: 80hp
Bore (mm): 92
Stroke (mm:) 82
Firing Order: 1432
Starter: Geared
Length (total): 25"
Width: 30"
Height: 14"
Re: SONEX, WAIEX, XENOS and ONEX @ Sonex Africa
Sonex Aircraft LLC has just launched their upgraded Sonex and Waiex Models, which will be refereed to as the "B" models. The major upgrades include a roomier cockpit, increased range and various new engine mounts that cater for virtually all makes, including the Rotax!
Our website is in the process of being updated, so watch this space. Follow the links below for a preview...
http://www.sonexaircraft.com/b-model/SN ... wn-390.jpg
http://www.sonexaircraft.com/b-model/Fw ... w2-366.jpg
http://www.sonexaircraft.com/b-model/So ... _9-366.jpg
http://www.sonexaircraft.com/b-model/So ... _2-366.jpg
http://www.sonexaircraft.com/b-model/b- ... on-800.jpg
