hi all,
A puncture has to be one of the worst dampers to any pilot - arrive at the airfield, ready to fly, and see you have a puncture. You should have heard the language at Ballito airfield last friday.
I know that for bicycles, one can get solid foam rubber inserts that go inside the tyre, therefore eliminating the need for air. I have even heard about these inserts that are not completely the right size, and you put abit of air inside. This way, you ride on air, but should you get a puncture, the air leaks,a nd then the rubber takes the weight. so, your tyre is not completely flat, but firm enought hat you can still roll, without damaging the tyre.
Anyway, has anyone heard about these for trikes / seen them / have a big investor / have a degree in designing / have a friend that works at Michelin??If you are lost, I'll try draw you pictures
Solid tyres?
Solid tyres?
Wheel barrow
kb,
Check out your local hardware store for solid wheel barrow wheels.
You'll have about the same effect.
Put some of these solid tubes in my lighties bicycle a few years back.
Poor little oke nearly burst a foofie valve trying to pedal the extra weight.
I'd rather be flying
Hi kb,
I have suffered the same frustration on a number of occasions. The problem I have is that the Jabiru has split rims and if the wheel is not pumped hard enough, when landing, the tyre turns on the rim and punctures the tube.
What is even more scary is when you land and the wheel deflates quickly, the effect is similar to having a blow-out in a car. This happened to me about 2 weeks ago and I landed up in the veld about 10 meters to the left of the runway. Fortunately the fence is not close to the runway.
So, I’m with you on this one. Hopefully someone comes up with a light weight “perma-tube†for aircraft tyres.
Users browsing this forum: No registered users and 80 guests
