Icom A3E to Icom A24: Transmit problem
kloot piloot
Postby kloot piloot » Thu Dec 17, 2015 8:50 am
Morning all,
I switched over from the Icom A3E to an A24. My headsets and intercom are all Air Magic.
The receive works well but when transmitting I get one hell of a squeal through my headsets. What could be the problem?
Any help or advice will be appreciated.
Roel
Roel Jansen
ZU-IAR powered by BMW 1200
MAGNIficent
Re: Icom A3E to Icom A24: Transmit problem
Postby MAGNIficent » Thu Dec 17, 2015 8:16 pm
You should adjust your side tone on your radio.
Plug headset in
Push PTT, while transmitting, adjust side tone level with dial to not have full feedback in headset.
See page in manual for adjusting side tone.
Hope your problem solved
kloot piloot
Postby kloot piloot » Fri Dec 18, 2015 10:16 am
Hi Magnificent,
It did try that as well. ST on zero or ST on 4, same squeal into headset when transmitting.
Just wondering whether the Airmagic chatterbox needs to be adjusted for a different radio?
Roel Jansen
mulderpm
Postby mulderpm » Sun Jan 31, 2016 1:58 pm
Noel, if I remember correctly, there is an adjustment required for different radios. Phone Paul. He will know for sure.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
kloot piloot
Postby kloot piloot » Mon Feb 01, 2016 12:41 pm
Thanks Paul,
I've sent him a message and will post here when sorted.
Roel Jansen
Postby Air Hog » Mon Feb 01, 2016 1:19 pm
As far as I know, the A24 has a known problem with the Chatterbox. Also had the problem when Paul was still available as support. Had to change my radio eventually.
mulderpm
Postby mulderpm » Wed Feb 03, 2016 9:06 am
See,
http://www.airmagic.co.uk/intercoms.html
"Special version (with integrated radio lead) available for Icom A6 / A24 radios - eliminates the RF feedback problems often associated with this radio type"
I see, the local web site no longer exists.
Paul Mulder
ZU-DBC Aquilla
Pretoria
SoLo
Postby SoLo » Thu Feb 04, 2016 10:37 am
Air Magic is no more and the owner has left RSA :evil:
Postby nicow » Thu Feb 04, 2016 10:42 am
... and the owner has left RSA :evil:[/quote]
since when?
vliegskool@hotmail.com
SoLo
Postby SoLo » Thu Feb 04, 2016 11:49 am
See viewtopic.php?f=1&t=23941&hilit=air+magic&start=60
Someone posted that he went back to the UK sometime middle of last year
If I am wrong, I would love to have his contact details :shock:
