Hi all
Any kitfox 2 owners out there ,advice for a new pilot
I have recently purchased a kitfox 2 ,lovely little plane ,with a 582 blue top ,2 blade warp drive prop
I only get 70 -75 on her ,iam told that normal cruise is about 85 mph .is there anyone out there who has a kitfox 2 with a 582 .
What speed do you get ,and what prop are you using.
My current setting on the prop is 9 degrees ,has a good climb but cruises +-65 at 5800 ,also makes a hell of a noise at the initial power up and take off ,we tried to reset the prop to about 11 degrees ,noise was still there
Cheers. Jon
0836007187
kitfox 2 prop and speed
- Solo cross country
Re: kitfox 2 prop and speed
Hi John, been there done that, if you have a 3.47:1 ratio on the gearbox........then get a P-Prop 72x52 from Pieter De Necker. You will have better climb and cruise speeds.
Jean
Jean
Thanks Jean
I have a 3:1 gearbox ,will the 72-52 work
No it wont. Give Pieter a ring at P-Prop, he will give you the right advice , here is his no:Jon Hewitt wrote:Thanks Jean
011 7935235
Jean.
Once we're on his plane X-32 put a propeller diameter of 1750 mm (3 gear), he began to fly almost as much as with the Rotax-912.
This applies to climb, and run, and cruising speed, and maximum speed.
Of course, it was the saber 3-bladed propellers.
Of course, it is the quietest.
The larger diameter will stop at maximum speed.
Small diameter will short-change forces at low speed.
he picture shows exactly it.
Thrust propeller diameter 69 "should be 175 kg.
Users browsing this forum: No registered users and 75 guests
