AT LONG LAST PROFESSIONAL AVIONICS REPAIR
Suesing
Postby Suesing » Fri Feb 27, 2015 10:40 am
Guys i have discovered an avionics company at FAWB who dont turn their noses up if you roll in there with a microlight and an avionics problem (radio or instrument) The work is of a top notch, certified standard , as well as awesome service. They are AME Aviation 012 5671253 .Reliability at long last. BUT remember FAWB is a controlled airfield , so you need to get prior permission from ATNS before rocking up there. If you are not experienced in landing at controlled airfields , make sure you do your prep , especially the taxiways-this can be daunting to a novice.
Jabiru Instructor ( Grade B)
