Hi fellow aviators,
During my last flight, at cruising RPM, I noticed a sudden spike in voltage (13.5 to 16vdc), normally constant at 13.5 vdc. This spiking returned to normal (13.5 vdc) within +- a minute. I landed, and did a ground run check at various rpm settings. A few spikes to 16 vdc, lasting for +_ a minute each re- occurred. (This fault is intermittent) The engine was shut down, and all electrical connections concerning the charging circuit were checked. No obvious faults were found. I suspect a possible voltage regulator fault. Is there a way to check the regulator before just replacing the unit? Any other suggestions? I am afraid of damaging the radio and instrument panel, and want to sort this out asap.
Andries
Spiking in voltage with Rotax 582 Blue top.
- ME 109
- Whats the right frequency?
Andries Kruger
Re: Spiking in voltage with Rotax 582 Blue top.
Hi , I also had that on a 582.........it was the voltage regulator.
J
J
- ME 109
Thanks JeanTree, one new regulator to be orderedJeanTree wrote:Hi , I also had that on a 582.........it was the voltage regulator.
J
Andries Kruger
Hi Andries, waneer is jy weer in SA? Ja, myne het dit ook gedoen. Die oorspronklike Ducati een toe met die lokal een van AMPTronic Systems vervang vir helfte van die prys. As jy die Ducati een het, hy is 3 fase, so, as jy will, kan jy seker nog die ongebruikte fase gebruik (spaar geel draad).
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
- ME 109
Hi Paul,mulderpm wrote:Hi Andries, waneer is jy weer in SA? Ja, myne het dit ook gedoen. Die oorspronklike Ducati een toe met die lokal een van AMPTronic Systems vervang vir helfte van die prys. As jy die Ducati een het, hy is 3 fase, so, as jy will, kan jy seker nog die ongebruikte fase gebruik (spaar geel draad).
Jammer ek lees nou eers jou voorstel. Die issue het kop uitgesteek tydens my laaste vlug voor ek terug moes gaan Singapore toe. Ek moet dus sodra ek terug is (25 Augustus) die regulator vervang, of die spaar fase gebruik. Ek het heelwat raad op die internet gekry, maar gaan eers die spaar fase check. (Dankie vir die voorstel). Waar kan ek die Amptronic system koop?
Sien jou binnekort!
Groete vir almal.
Andries Kruger
By Amptronic, 011 679 2754 of by Alex Rudd. Myne by Alex gekoop, hy is nader.
Paul Mulder
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
- ME 109
Much appreciated Paulmulderpm wrote:By Amptronic, 011 679 2754 of by Alex Rudd. Myne by Alex gekoop, hy is nader.
Andries Kruger
- ME 109
Some feedback on the charging issue. Replaced the voltage regulator, supplied by Amptronic. Charging at 13.5 VDc. Two hours flown since replacement. Problem solved!
Andries Kruger
Users browsing this forum: No registered users and 56 guests
