two blade prop vs 3 blade aeros prop
- Learning to fly
i have a rotax 503 with an E gearbox and have a problem with my aeros props that we just cant seem to get them balanced perfectly.At full revs i get a vibration.I have been thinking of fitting a Pieter de necker 2 blade prop onto the plane.Will the performance be just as good??Ihave sent the aeros props off for balancing twice and just cant seem to get them right.Anyone using the two blade De necker are you happy with it???
- John.com
Re: two blade prop vs 3 blade aeros prop
I converted from Aeroprop to PProp! Great decision. Great torque and good fuel efficiency. Call Pieter on 011 793 5235. Tell him I sent you!in the sticks wrote:i have a rotax 503 with an E gearbox and have a problem with my aeros props that we just cant seem to get them balanced perfectly.At full revs i get a vibration.I have been thinking of fitting a Pieter de necker 2 blade prop onto the plane.Will the performance be just as good??Ihave sent the aeros props off for balancing twice and just cant seem to get them right.Anyone using the two blade De necker are you happy with it???
Regards, John
John Comley
Magaliesberg, South Africa
If you want a wood prop I may have one for you. As good as new.
Zero ate one for too 7 double ate too sex
You also have another option to fit a locally produced 3 blade composite NC prop. I am using one and it is excellent.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
ZU-DBC Aquilla
Pretoria
- Learning to fly
Thanks John, I will do that
Users browsing this forum: No registered users and 65 guests
