My 912 does not switch off, I have fitted new P leads and switches, still does not work,
Has anybody had this problem?
Niloc
912 not switching off
Re: 912 not switching off
Piepie sy plugdrade nat, of slaat hom met n dropperpaaltjie dood........ Seriously. Niloc, check the magneto grounding wires where it goes into the igniter boxes. Probably broken off inside. It will cost you (HOPEFULLY not), a new electronic box, or you can revert to my opening advice! OR the switches can be faulty, or one of them.
Dankie Boet, n vier pond hammer klink meer na die ding! I have come to the conclusion that the gremlin is in the box, i will need a set of drawings, the I can repair.
As hy nie wil afsit nie wil hy seker vlie so Vlieg hom
Goose wrote:As hy nie wil afsit nie wil hy seker vlie so Vlieg hom
Niloc, when you found the fault. we would like to know the cause of the problem too!
