I got some feedback from the manufacturers. Apparently I still have the old type Pylon and Lowerboom on my trike. Aliminium inside aliminium tube. The new spec is a steel inside an aliminium tube.
This trike has been flying like this since '87. Will the trike be that much stronger with new spec tubes? Or only stronger on the landing? Where will the biggest benifit lie for upgrading.
I will need to buy a profile tube as well because my old spec lower boom is shorter..so when i install new , i need replace the profile tube.
Looks like a total cost of R7000 incl labour. Excl trasport.
Is it worth upgrading? Or should I rather put the R7k towards a BRS chute?
Do I really need to upgrade my Pilon+Lower boom
- Wargames
Re: Do I really need to upgrade my Pilon+Lower boom
As I understood you should replace your pylon every 500hours.
I would replace the items you mentioned, and forget about the BRS. If your trike is well maintained, it is just a weight ballast.
- SkySketch
- Solo cross country
Do not agree with you, the day you end up in bad weather or something unexpected goes wrong, and you have a structural failure a Chute is most probably going to save your life, even a engine out in risky terrain!Wargames wrote:As I understood you should replace your pylon every 500hours.
BRS is a must in my opinion and it makes flying so much more enjoyable knowing that you have a backup!
Juan-Peter (JP) Schulze
17
RV Freak!!!!
RV...Das Flugzeug
17
RV Freak!!!!
RV...Das Flugzeug
- Wargames
True, but it will also make you take more chances. In my opinion a BRS is overrated, as what we do is for enjoyment, and we should never push the limits so far that the BRS is necessary. And oh yes, a BRS wouldn't make my flying more enjoyable than what it is already, in fact, with a BRS fitted on my plane I would be over MTOW solo!!SkySketch wrote:Do not agree with you, the day you end up in bad weather or something unexpected goes wrong, and you have a structural failure a Chute is most probably going to save your life, even a engine out in risky terrain!Wargames wrote:As I understood you should replace your pylon every 500hours.
- SkySketch
If that is the case then you ( generalizing here ) are not disciplined enough and should not be flying!Wargames wrote:SkySketch wrote:
I write this with respect, I apologize if it seems ruse and disrespectful!
Kind Regards JP
17
RV Freak!!!!
RV...Das Flugzeug
17
RV Freak!!!!
RV...Das Flugzeug
Do both, pylon and BRS!Maybe wrote:I got some feedback from the manufacturers. Apparently I still have the old type Pylon and Lowerboom on my trike. Aliminium inside aliminium tube. The new spec is a steel inside an aliminium tube.
- Wargames
http://en.wikipedia.org/wiki/RuseSkySketch wrote:I write this with respect, I apologize if it seems ruse and disrespectful!
According the above website:
A ruse is an action or plan which is intended to deceive someone.
Thanks, now I also know.
If the intension was to write "rude", its still not a problem. BRS is unfortunately one of those items on which everyone has there own opinion on. Don't know of any cases where a BRS actually saved someone, although I can think of a couple where pilots who didn't have them could have been saved if they had them on board.
- SkySketch
Started a new thread
viewtopic.php?f=13&t=13617&p=135068#p135068
17
RV Freak!!!!
RV...Das Flugzeug
17
RV Freak!!!!
RV...Das Flugzeug
ok, ive decided to not replace the pylon, boom and profile tube..... - yet.
These items only has 650 hours on. According to the spec, only needs replacement after 1500hrs. So i will think about replacing them around the 1000 hr mark.
And then....maybe start thinking about brs.
