Twisted flying wires
- Biggles
I see that some trikers twist thier two flying wires together. I was wondering if there is a reason for that. I swear, in the assembly instructions for my Spirit 15 wing, that it said to nake sure the flying wires are not twisted.
Trike pilot
Aerotrike Scout
ZU-DNP
Aerotrike Scout
ZU-DNP
- Tribal Croc
Re: Twisted flying wires
Mine are twisted as well, not sure if it’s a problemBiggles wrote:I see that some trikers twist thier two flying wires together. I was wondering if there is a reason for that. I swear, in the assembly instructions for my Spirit 15 wing, that it said to nake sure the flying wires are not twisted.
![Question :?:](./images/smilies/icon_question.gif)
All Aerotrikes and Aquilla's I have seen have thes twists
I once made the observation that the cables we fly with are very thin
Someone then told me that he persanally heard a very reputable trike-manufacturer state that ONE STRAND of the cable is strong enough to keep everything together - It put my mind at ease as there are PLENTY of strands in a cable
Personally I would not worry about the twist, I know it causes a pull to one side if more twists one one side than another
For interest sake, the Mainair does not have these twists
D
![Confused :?](./images/smilies/icon_confused.gif)
![Shocked :shock:](./images/smilies/icon_eek.gif)
D
Big D
- Signed up at flight school
The twisted in the assembly manual refers 2 cables being snagged around something or twisted on it self that could cause damage to the cable (break strands) when you pull the wing tight. The twisted flying wires is merely to keep the cables togther when you derig and store the wing. This "new one" cable also has less change to twist than the 2 separate cables.
- Cloud Warrior
- Top Gun
The twists in the wires and the wires being so tight on an Aquilla 2 wing are there for a reason. They prevent the wing from being over stressed in turbulence.
Every time an Airborne driver over here sees my trike, they flip - all the Airborne trikes have wires that are well separated and hang a bit "pap". They reckon its all very wrong. But then how many Aquillas have had wing failures............
Solowings Aquilla
32-4817
32-4817
Hi Guys
My Aquilla wing has wires that hang pap but when I fly they are automatically pulled tightm They are not twisted and I have twice experienced severe turbulence when caught in a sudden front passing through[45mph gusting 55mph] Poepol knypped severely but aircraft handled it very well although the pilot was scared shitless. Wires did not even groan and after landing intense inspection showed no damage. Wether to twist or not I do not know
Bryan
ZU BFR
Bryan
ZU BFR
- Cloud Warrior
- Top Gun
Bryan
Phone Solowings and have a chat to them about why they do it. They do it for good reason.
Sebastian
Sebastian
Solowings Aquilla
32-4817
32-4817
- KFA
If I remember correctly, they are supposed to have 5 twists in them.
- Biggles
Makes sense to have twists in them... it will have a "shock absorbing" effect as the wires pull tighter. what concerns me is the effect the wires rubbing against each other.
I have checked teh manual for the Spirit 15 Wing and no mention of twisting the flying wires around each other. Only reference to checking that they are not twisted.
Trike pilot
Aerotrike Scout
ZU-DNP
Aerotrike Scout
ZU-DNP
As far as i know the reason for the twists in the flying wires effects the DYHEDRAL of the wing . The more dyhedral the more stable the wing but also more difficult to make it roll into a turn. Dyhedral is increased by twisting the wires more times and vice versa.
Aquilla has 3 turns as far as i can remember.
Atom
Atom
- Cloud Warrior
- Top Gun
Aquilla 2 wing is 5 - 6 turns.
Solowings Aquilla
32-4817
32-4817
- John Young
- The Boss
Ever heard a Hobi Cat parked in the wind at night - the cables flutter and resonate off the mast non-stop.
The reasons the flying wires are twisted particularly on the Aquilla 1 are to -
1. Stop the potential flutter, and
2. Adjust the length of the flying wires once the dihedral has been set with the landing wires.
The dihedral would be decreased by twisting the flying wires.
John ZU-sEXY
Hi Atom,atom wrote:Dyhedral is increased by twisting the wires more times and vice versa.
![Wink :wink:](./images/smilies/icon_wink.gif)
John ZU-sEXY
