Leaded or unleaded...
- DarkHelmet
- Cloud Warrior
- Top Gun
I thought it was unleaded that had no/less alchohol. I was told to stick to leaded if not flying every day as it absorbs less water and maintains it's octane rating better that unleaded. Looks like this may not be the case. Where did you get this info from, Redeye????Redeye wrote:Why use leaded fuel if Rotax recomends Unleaded-- ?? Also there is no alchohol in unleaded
Andrew
Savannah flyer
S25 55 54.80 E028 04 34.40
Savannah flyer
My old micro GURU at panorama bill anderson did a lot of research into this for his micro scool at the time- as students we had to pitch up with a 20 litre can of gas for our lesson- he only alowed unleaded- Worked for me
ever since 1200 hrs with no fuel problems-- The Rotax manual that comes with your motor also recomends unleaded and only Castrol oil -- I did use outboard oil in my 618 though
Hi Morpheus,
Apologies for not replying sooner - I forgot to keep an eye on this thread. I see you found BP in Cape Town and the price is similar here in Gauteng. The 20x500ml case price of R193.00 equates to 16.93 per litre. If you buy a 20 lt drum the per litre price is 13.61 - keep a few empty bottles for decanting.
You asked how long I've been using it.. all my Microlighting life. The school trikes at Springs all use it and those motors really work. I know of an ex-school Hornet Trike with a 503 Rotax that has over 1000 hours on it and to date has not been opened.
Cheers.
Cheers.
- PastMaster
- Ready for the first flight
I include the Rotax web site adress. They recommend unleaded unless a certain thing happens vapour lock and Castrol TTS oil
http://www.rotax-aircraft-engines.com/p ... d00286.pdf
Just managed to get a response out of CaltexSonex711 wrote:I thought it was unleaded that had no/less alchohol. I was told to stick to leaded if not flying every day as it absorbs less water and maintains it's octane rating better that unleaded. Looks like this may not be the case. Where did you get this info from, Redeye????Redeye wrote:Why use leaded fuel if Rotax recomends Unleaded-- ?? Also there is no alchohol in unleaded
I guess I'm switching back to Caltex un-leaded...
Hi Andrew,
Thanks for the query.
From the batch fuel certificates I have on file for the fuel in the
Gauteng area coming out of the Sasol supply area, the current alcohol
levels are below 1 % v/v for both leaded and unleaded grades. The SABS
specification for unleaded allows up to 8 % v/v alcohol and up to 2 %
v/v in leaded petrol.
Provided your storage system is kept dry, there should be no quality
issues with storing this fuel for up to a month before use.
Hope this helps. Let me know should you have further queries.
Simon
Product Engineering Specialist
ChevronTexaco
Andrew
Savannah flyer
Savannah flyer
I dont know if it still is like this, in 1985 I used to help my dad at work(bring a boy child to work) at Sasol plant Secunda, all the different oil companies filled their trucks at the same point as the Sasol trucks Deductive reasoning, after reading the above letter, tells me it is still like that.fuel in the
That is why I have started to put in their "Dual Fuel" the extra octane of super and no lead for the "vapour lock"
Maybe I am totaly wrong
What is vapour lock
IFLYHI, from my limited knowledge, vapour lock occurs when bubbles form in the fuel lines. It can be caused by..IFLYHI wrote:What is vapour lock
1) lines getting hot (in engine cowl)
2) High alt flying
3) fuel being sucked rather than pushed (like if your elec fuel pump on a t-bird failed and the mechanical pump has to "suck" the fuel up to the engine from the tanks causing a pressure drop in the fuel line).
IMHO, the higher the octane rating, the less likely vapour lock is - bubbles need a higher temp or lower pressure to form.
Perhaps one of the AP's on the list can give more detailed info...
Andrew
Savannah flyer
Savannah flyer
Hi guys,
Just a thought. Remember that the guys recommending chainsaw oil are also the guys selling spares.
Outboard oil has alow flashpoint, and cannot lubricatre as effectively.
I use TTS and Royal Purple racing. Expensive maybe, but far cheaper in the longrun!!!
Great day for flying with the one-eyed-dick!!!
Users browsing this forum: No registered users and 35 guests
