This engine has been standing on it's belly since I bought it. I mounted it last weekend on a mock-up firewall on a stand to be able to start sorting out manifolds etc. With it off the workbench I could see underneath it and discovered that the push rod tubes on one side has all been dented inwards in a straight line. The engine seems to have been dropped at the one side on an edge of some sort.
Volkspares sell these at R85-00 but I need to buy a complete gasket set to get the seals for the tubes and the paper cylinder gaskets.
Is there any place where I can source these without having to buy a complete gasket set?
VW Type 1 Engine push rod tubes and gaskets
Rhino? Fck the Rhino, save the White Ou.
(met permissie van Gyronaught)
Re: VW Type 1 Engine push rod tubes and gaskets
Thanks to some e-mailed advice I got the tubes fixed.
Dankie!
Dankie!
Glad to hear you came right
And tube seal also sorted
Glad for you Eddie
Thank you Jean
