Sorry for my ignorance.
Can anybody briefly explain to me what difference will there be in a Rotex 582 Blue Top with 480 HRS on the machine in comparison with a Sliver top, 582 with the same HRS.
Thanks very much.
582 Blue Top/ 582 Silver Top.
- Blue Max
- Air Hog
Re: 582 Blue Top/ 582 Silver Top.
- Duck Rogers
Paul...Blue Max wrote:Sorry for my ignorance.
Thanks very much.
Grey crankshaft = 17mm thick conrods and 24mm crankpin
Blue crankshaft = 18mm thick conrods and 26mm crankpin
by the way...Grey or Blue cranks makes no bloody difference. I see an equal number of crank failures.
Cooling system modified on the Bluetop to prevent cold seizures. Fly the Greytop right and you wont have a cold seizure either
Rubber seal on Greytop waterpump shaft changed to a Ceramic seal on the Bluetop. A definite improvement
That's only the changes between the two. I presume that's what you meant with your question otherwise its impossible to tell the difference because its 2 different motors flown differently in different conditions for 480 hrs. You will have to open them both up inspect and measure everything ( I don't think that's what you meant but that's what you asked )
- Madman
Howdy
Flying my trike which is a Silver Top and having flown Oom Polla's Raptor over the Easter weekend which has a Blue Top...the only big difference I noticed is that when you put the silver top in a dive, it drops the water temp very quickly, so you have to keep her at an idle to maintain water temp...with the blue top, you do not see a drastic water temp change when thrown into a dive
Also with the warming up in the mornings, the Silver top does take a little longer, but nothing to write home about
On the performance side, I did not feel a difference in power
So I would watch the water temp when doing a steep spiral dive or when you trying to lose altitude quickly...otherwise..alles is lekker
" So I would watch the water temp when doing a steep spiral dive or when you trying to lose altitude quickly...otherwise..alles is lekker :mrgreen "
In a spiral dive you should watch the ground, not the water temp.
- Duck Rogers
And that's exactly why they changed the cooling system on the Bluetop.Madman wrote:...the only big difference I noticed is that when you put the silver top in a dive, it drops the water temp very quickly, so you have to keep her at an idle to maintain water temp...with the blue top, you do not see a drastic water temp change when thrown into a dive
Performance wise there is no difference. Its the same specs on both
- Madman
Yeahcoline wrote:" So I would watch the water temp when doing a steep spiral dive or when you trying to lose altitude quickly...otherwise..alles is lekker :mrgreen "
Users browsing this forum: No registered users and 29 guests
