Rotax 582 will not pick up revs
- cjkrit
After standing for 4 months I started my Rotax 582 blue top this morning.
It fired without problems but will only idle.
The moment I open the throttle it simply dies.
It was running perfectly the last time.
Advice please.
Christo Kritzinger
0825760214
Advice please.
Christo Kritzinger
0825760214
Re: Rotax 582 will not pick up revs
Your main jet/s are gunked up, but the idle jets are still open. Give the carbs a good cleaning.
- cjkrit
I have checked the jets - seems nice and clean and open.
I think it must be something in the carb but can't identify the problem.
Any other ideas?
Any other ideas?
- Kalahari
- Survived first engine out
Did one of the carbs needles not perhaps came loose, in other words, if you pull the throttle the plunger move upwards but the needle remain stuck in the main jet? What happen when you pull the choke when you try to rev it?
Arrogance and rudeness are the training wheels on the bicycle of life for those who can not keep their balance without it!
- cjkrit
I have checked the needles and they are moving freely. I have not tried to apply choke when I rev it - will do that.Kalahari wrote:Did one of the carbs needles not perhaps came loose, in other words, if you pull the throttle the plunger move upwards but the needle remain stuck in the main jet? What happen when you pull the choke when you try to rev it?
What I have noticed that when engine is idling there is a lot of blue smoke - also not something which i am used to.
Thanks everybody for your advice. Much appreciated.
Very frustrated at the moment.
Regards.
- Nacho
- Survived second engine out
Remove your main jet and clean them with a thin wire through the holes. Make sure all the holes are nice and clean. You can't always see the dirt purely by doing a visual check.
If I were you I would remove the carbs. Disassemble completely, clean all ports. Inspect all components for wear while you are at it. Adjust the carbs using the standard config. (Clip on no 3 from the top and Air screw fully in and one full turn out)
Do it properly and do it right, get complete peace of mind. This is the part that feeds your engine, you want it to be 100%
See attached doc as well.
- Servicing_Bing_54_carburetor.doc
- (53.5 KiB) Downloaded 1101 times
- cjkrit
Thanks for all the info!!
Where do I order the carb rebuild kit from for the Bing 54?
Regards.
Regards.
Comet Aviation supplies. Do not use a wire to clean the carbs. Go buy a good quality carb cleaner and soak the jets and clean.
Agree, wire can make small gouge marks not visible to the eye, which in turn alters the mixture on that particular carb.KFA wrote:Comet Aviation supplies. Do not use a wire to clean the carbs. Go buy a good quality carb cleaner and soak the jets and clean.
- Wargames
When last did you replace your fuel filter? have you checked for any cracked pipes?
The Naked Trike
ZU-AVL
"I hate CIRCLIPS!!"
ZU-AVL
"I hate CIRCLIPS!!"
- cjkrit
Thank you everybody for your input.
I have ordered new fuel lines, filter, carb rebuild kits, carb cleaner etc.
This is going to be my easter weekend project.
Hold thumbs.
Thanks once again.
Hold thumbs.
Thanks once again.
- cjkrit
I took the carbs apart and cleaned everything with carb cleaner.
It is better and I was able to get to 6300rpm but with very small and carefull throttle increases.
I think balancing or synchronising of the carbs needs to be done also.
The moment I apply rapid throttle it simply stops.
Kalahari,
When I apply choke I can easily get it to high revs. Do have a remedy for this stoppage on rapid throttle problem because you asked that specific question.
Christo Kritzinger
Kalahari,
Christo Kritzinger
Make sure the little breathing hole on your vacuum fuel pump is open, and the pump must be installed with the hole to the bottom, not upwards.
Die ringe kan moontlik vas sit wat blow by veroorsaak en of die mengsel moet gestel word witwillem
Users browsing this forum: No registered users and 32 guests
